just turboed, now MAP sensor code?
Old Aug 19, 2006 | 05:49 AM
BIG RICH's Avatar
Default just turboed, now MAP sensor code?
Before I go on I did search and I read the FAQ, but didn't find exactly what I was looking for. OK heres what I got, Its a 91 CRX Si with the stock d16a6 and ECU, I don't kbow what size the turbo is, but its no bigger then a stock DSM t25. I'm running stock injectors with an FMU. Its making 5-6 PSI right now and when I get on it, it throws the MAP sensor code. I've read alittle about the GM 3 bar and the motorola 2.5. Can I use either of these with the stock ECU? I saw one topic where the guy used his stock map sensor as the "plug" for the harness, but wired the GM 3 bar up to that. here it is
https://honda-tech.com/zerothread?id=1440585
I do plan on going with an ECU upgrade, but still not sure which one I'd like, any suggestions?
Old Aug 19, 2006 | 05:58 AM
F20Cteg's Avatar
Default Re: just turboed, now MAP sensor code? (BIG RICH)
To use your current fuel- setup, you would need to install a check valve in between the map sensor and the throttle body. This will prevent the map sensor from "seeing" boost and thus throwing a CEL. you don't need another MAP sensor.
Personally I would ditch the FMU and get your ecu chipped and have it tuned. With that the stock MAP sensor can read up to 11psi ish.
Old Aug 19, 2006 | 06:02 AM
BIG RICH's Avatar
Default Re: just turboed, now MAP sensor code? (F20Cteg)
I forgot to mention that I have 6 check valves in line to the MAP and still throws a code. I do want an upgraded ECU, but right now I just want the car driveable.
Old Aug 19, 2006 | 11:57 AM
ATYPR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIG RICH &raquo;</TD></TR><TR><TD CLASS="quote">I forgot to mention that I have 6 check valves in line to the MAP and still throws a code. I do want an upgraded ECU, but right now I just want the car driveable.</TD></TR></TABLE>
try this http://www.synapseengineering.....html
Old Aug 19, 2006 | 12:14 PM
BIG RICH's Avatar
Default Re: just turboed, now MAP sensor code? (FUCATYPR)
don't the check valves work the same way? I thought the check valves were a cheaper way of going about doing it?
Old Aug 19, 2006 | 01:29 PM
95dc2teg's Avatar
They are the same as getting that, but i guess its just for a cleaner look. Also recheck ur valves to the map sensor and see if that fixes the CEL
Old Aug 19, 2006 | 02:09 PM
BIG RICH's Avatar
Default Re: just turboed, now MAP sensor code? (95dc2teg)
yeah. I was kind of confused with them. 3 of them had arrows, so I assumed they were the direction of flow. so the arrows point out to the atmospere. then the other 3 don't have arrows, but the package sort of explained it. I'll try a missing link, unless I find an ECU upgrade in my price range.
Old Aug 19, 2006 | 10:41 PM
F20Cteg's Avatar
Only one check valve is needed. Any more is just asking for mistakes.
Old Aug 22, 2006 | 03:48 PM
BIG RICH's Avatar
I started with 3 and it didn't help at all, the car would still shut down if I got on it. I've got the 6 now and it helps alittle. the car still runs fine, but I'm sure it would be better with the map sensor fixed. can I use a 3 bar map sensor with my stock ECU?
Old Aug 22, 2006 | 05:45 PM
F20Cteg's Avatar
No, unless the ecu is chipped and the code added for boost and scaling the injectors.
&gt;&gt;&gt;&lt;&lt;&lt;
BigbamaBen
Oct 4, 2013 02:45 AM
92SikHatchBak
Engine Management and Tuning
Jan 6, 2010 09:38 PM
88crxdxfastwhip
Mar 13, 2006 06:35 PM
JR Integra
Jan 23, 2004 08:48 PM
fast[R]
Jul 18, 2002 03:00 PM
