junkyard turbo
Old Dec 6, 2002 | 07:07 PM
dominate9's Avatar
Default junkyard turbo
I want to turbo my 95 Prelude but I don' t think I'll need a T3/T4 cuz I'll only 6 lbs max and probably 3-4 lbs daily. I figured that a T3 with a 45 compressor trim and .60 A/R should work for me. What car is the junkyard could I get a turbo from that would be the closest to what I'm looking for?
Old Dec 6, 2002 | 07:59 PM
Blaze45's Avatar
Brrraaaap!
Default Re: junkyard turbo (dominate9)
Firtst off your gonna want to bost more then 6lbs max. 3lbs wont cut it. trust me. Use the search button and look this stuff up man theres a ton of stuff archived.
Look @ http://www.homemadeturbo.com
hes turbo'd quite a few cars and has an excellant FAQ.
Blaze
Old Dec 6, 2002 | 08:18 PM
b16ahybrid's Avatar
Yeah trust me, 3psi is not worth it, i'm runing 5psi rite now and it's killing me because my car feels gutless compared to the 8psi that i normally run..
Imo if your going to turbo your car, run 5psi min...any less it's a waste of money....now that we got that out of the way...I don't think that you will find a turbo that will suite you engine from a junkyard.Your best bet is to contact cheapturbo.com they have decent prices on new turbo's and they can set you up with the perfect turbo for your needs.Thats what i would do....oh wait i did do that....
Old Dec 6, 2002 | 10:11 PM
mamaboy's Avatar
Ford thunderbird SVO...i believe...that's where I got my turbo...but the volvo and saab turbos should work fine....I found those two turbos in one trip to the local pick your part....tee hee....oh....and the volvo turbo...I don't recommend...fabrication is necessary to mount it to the turbo manifold......
[Modified by mamaboy, 7:13 AM 12/7/2002]
devney
Mar 24, 2010 11:04 AM
92civicx
Aug 27, 2007 10:39 PM
b18c1wes
Apr 5, 2005 06:29 PM
Ivan
Jul 17, 2002 06:40 AM
