Jrsc removed, help me ID some parts
I'm trying to identify the PCV valve. I found a lot of oil in my jrsc and manifold, so I would like to see if it is blowing past the PCV. Can someone please circle the PCV in this pic? BTW, what is the black box to the right of the oil filter?
Re: Jrsc removed, help me ID some parts (intercooledJRSC)
It's usually ON the intake manifold...not sure what happens to it with the charger though. The black box is the stock "catch can"
As someone already pointed out, the PCV valve is the red plastic piece attached to the hose. That is stock location for the vtec engines, whereas the B18B non-vtec has the PCV on the valve cover. The black box is the oil vapor separator (catch can).
Re: (roadrunner)
I will be adding the Endyn catch can to my car as soon as it arrives in the mail. It should cure my "blow-by" issues, and cut down on my massive oil consumption. From the installation directions, it looks like it is mounted in-line ahead of the stock separator box. I'm wondering, while I'm digging around that area, whether I should clean out or change the stock separator box. Is there any kind of filter element in there that can be cleaned out?
