JE rings install?
Old Mar 12, 2002 | 07:25 AM
paulzy's Avatar
Default JE rings install?
Whcih way do they go in from bottom up?
is it:
oil ring
2nd compression ring
1st compression ring
top oil ring
Help
Old Mar 12, 2002 | 09:28 AM
skilzz's Avatar
Default Re: JE rings install? (Slow_ass_4dr)
from the top of the piston the rings go...1st compression, second compression then oil control rings. be sure to stagger them (rotate the openings away from each other)
Old Mar 12, 2002 | 10:23 AM
dustin's Avatar
Compression rings are always on top... oil control rings below...
Also, remember that JE rings are file fit! Don't just install them without filing the end gap to spec....
Old Mar 12, 2002 | 11:30 AM
rtype11's Avatar
you guys cant let him do this on his own, take it to an engine builder to put together. there is a special tool they have to file them and to expand them into place and they know the stagger sequence, dont do it yourself.
Old Mar 12, 2002 | 12:22 PM
dustin's Avatar
Default Re: JE rings install? (rtype11)
hehe
Old Mar 13, 2002 | 12:07 AM
paulzy's Avatar
Default Re: JE rings install? (dustin)
alright, thanks....
Old Mar 13, 2002 | 12:21 AM
Ray's Avatar
Ray
New User
read the instructions, I mean really read and understand, should tell u everything you need.
Old Mar 13, 2002 | 01:03 AM
paulzy's Avatar
Default Re: JE rings install? (Ray)
they are informative, but not really informative all at the same time... ! I'll probably just take them back to the machine shop
Destructive-
Aug 21, 2009 08:24 PM
Vpenh
Aug 8, 2006 02:49 PM
Witty
Jul 3, 2003 06:20 PM
hybrid_KJ
May 30, 2003 05:48 PM
275Performance
Jan 2, 2003 04:51 PM
