jdm d15b turbo dyno
jdm d15b turbo dyno
well just wanted to post my dyno graph just to see what you guys think. im happy with what i got other than the graph being very shaky, is that normal?
my set up
-straight t3 42-48
-log manifold
-big intercooler?
-"2" piping
-greddy type rs bov
-xs boost controler
-msd inline fuel pump with an fmu
this run was on 8 psi
[IMG][/IMG]
[IMG][/IMG]
my set up
-straight t3 42-48
-log manifold
-big intercooler?
-"2" piping
-greddy type rs bov
-xs boost controler
[IMG][/IMG]
[IMG][/IMG]
Re: jdm d15b turbo dyno (sohc_turd)
am i risking it though? i am building a b18b turbo set up know but i dont want to blow this thing up before im done with the other set up.
Re: jdm d15b turbo dyno (h kid)
Yes, you are risking it with running 13:1 under boost, that is not very safe. Don't take your car back to that "tuner."
If you want a quick fix, buy an adjustable fuel pressure regulator and start upping your fuel pressure until you get around a 11.8:1 to 12.0:1 a/f ratio.
Re: jdm d15b turbo dyno (PrecisionH23a)
what should my a/f be at? and yea i was going to take this thing to bubba but it was a spur of the moment thing.
I just told you, between 11.8:1 and 12.0:1
If you are running stock static fuel pressure right now (44psi), my guess is you will need around 52-54psi to put you where you want to be at. You may also want to upgrade to a high pressure fuel rail while you are at it.
ok cool thanks, ill do that next pay check. but cant i just get bigger injectors to do the same? wouldnt that be better?
Re: (MidShipCivic)
D15B VTEC can only use D16 rods. The use of any D16 pistons will result in the piston sticking out of the block. D15B pistons have a super low compression height to allow the use of the longer D16 rods.
Re: (F20Cteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20Cteg »</TD></TR><TR><TD CLASS="quote">D15B VTEC can only use D16 rods. The use of any D16 pistons will result in the piston sticking out of the block. D15B pistons have a super low compression height to allow the use of the longer D16 rods.</TD></TR></TABLE>
I should've said that more specifically.
Re: (h kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h kid »</TD></TR><TR><TD CLASS="quote">is it safe running it that lean? will it blow because of it?</TD></TR></TABLE>
No, not safe. Yes, can blow.
The tuner guy doesn't know what he is talking about if he said that is safe. Look at the spike right around 4K... that is where you will have problems...
Bigger injectors and some real management are in your future.
Re: (93turbo16)
He was telling me to gap my plugs closer like at 30-32 and for all motor go for 40-45. is that true couse I've always thought the opposite
