Intercooler questions
Old Dec 14, 2005 | 11:35 AM
ferio 95's Avatar
Default Intercooler questions
Ok ive been looking into making my own fmic piping and read/hearing alot of mixed thoughts on intercooler piping that i want to clear up.
1.) less piping = quicker spool
2.) 3" piping is to large for cars making less then 400whp
3.) sharp bends cause lag and or compressor surge
4.) most ideal location for BOV is within 6 inches of TB
5.) this is actually a part B to #2, but ive also noticed that most intercooler kits are like 2.25 from turbo to intercooler then become 3" as it meets the intercooler. then is 3" from intercooler to throttle body. supposedly this helps with throttle response
any care to answer these?
Modified by ferio 95 at 4:31 PM 12/14/2005
Old Dec 14, 2005 | 11:39 AM
digital sol's Avatar
Default Re: Intercooler questions (ferio 95)
bump
im subscribed
Old Dec 14, 2005 | 11:47 AM
ferio 95's Avatar
Default Re: Intercooler questions (digital sol)
guess im not the only one that wants to know this
Old Dec 14, 2005 | 11:54 AM
Importordomestic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 &raquo;</TD></TR><TR><TD CLASS="quote">Ok ive been looking into making my own fmic piping and read/hearing alot of mixed thoughts on intercooler piping that i want to clear up.
5.) this is actually a part B to #2, but ive also noticed that most intercooler kits are like 2.25 from turbo to intercooler then become 3" as it meets the inter cooler. then is 3" from intercooler to turbo. supposedly this helps with throttle response
any care to answer these?</TD></TR></TABLE>
1.) not sure
2.) just match your ic piping between your IC ant throttle body to be the same size as the throttle body or slightly larger
2-b.) as stated try to match the housing as best you can
3.) not sure - but your guess seems plausable
4.) most stock turbo cars (MR2 turbo) have the BOV within 6" of the turbo - anywhere in the system will work fine
Old Dec 14, 2005 | 12:08 PM
PnkRokCountryboy's Avatar
Default Re: Intercooler questions (Importordomestic)
very interested also
Old Dec 14, 2005 | 01:07 PM
B18 CYA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 &raquo;</TD></TR><TR><TD CLASS="quote">5.) this is actually a part B to #2, but ive also noticed that most intercooler kits are like 2.25 from turbo to intercooler then become 3" as it meets the inter cooler. then is 3" from intercooler to turbo. supposedly this helps with throttle response
Huh? 2.25 from turbo to intercooler. then you say 3" from intercooler to turbo. do you mean 3" from intercooler to throttle body?
Old Dec 14, 2005 | 01:31 PM
ferio 95's Avatar
Default Re: Intercooler questions (B18 CYA)
lol i didnt even notice that but yes thats what i ment
Old Dec 15, 2005 | 12:01 AM
Pelican's Avatar
If by less piping you mean smaller diameter and therefore volume of the air through the system, yes. It will take less time to raise the smaller of two volumes to the same pressure.
kinda relates to number 1. The bigger the piping the harder the compressor will work to pressurize all of it. You use bigger and bigger piping because compressor is set up to push too hard against the air because the engine can't suck it in fast enough.
Same rules apply to exhausts. a sharp turn limits flow and causes backups
Probably always be in debate but I disagree. The purpose is to prevent the turbo from pressurizing a closed system because the TB is closed. So it makes sense to me to be as close to the turbo as possible, BUT............ changes in pressure are immediately felt throughout the system so it shouldn't matter where the BOV is located.
I have a lot of crazy ideas but I bet its just because the kitbuilders don't make the ICs and the difference is probably arbitrary
Old Dec 15, 2005 | 07:20 AM
ferio 95's Avatar
Default Re: Intercooler questions (Pelican)
hmm thanks
Old Dec 15, 2005 | 07:21 AM
ferio 95's Avatar
also what i ment by less piping meaning faster spool. in case you havent picked up on it i have a 240/sr20 anyway alot of the tracked cars or drift cars like to run the vmount setup because it alows more air to the radiator and intercooler but its also nice to have because its less piping on the intercooler which is supposed to give waybetter response and quicker spool. its possible they are confusing response for spool but either way less pipe is supposed ot be faster boost since less air travel
ashtons300zx
Dec 13, 2011 10:12 PM
ntoxicatedtigah
Jan 27, 2009 03:38 PM
ghettochild
Jul 11, 2004 09:42 AM
Soon_2b_evil
Oct 12, 2003 03:04 PM
