intercooler/ic? piping shortcut
Old Jan 25, 2009 | 04:54 AM
ntoxicatedtigah's Avatar
Default intercooler/ic? piping shortcut
ok this might not make alot of sense, but i'll try to explain it my best. so i was wondering what intercooler do you know of that would alow u too do the ic piping short cut from the throttle body down to intercooler instead of the long way, which would be from the throttle body to the side where the hole is down the over to the IC? or am i wrong and u can pretty much do it to any intercooler? well the reason i was asking is because i was looking at some intercoolers and they're a little long so it would actually HAVE to go around and up through the hole. anyways, what intercooler? this would be going into an ek btw.
Old Jan 25, 2009 | 05:17 AM
Default Re: intercooler/ic? piping shortcut
or does anyone know if there is any other company that makes backdoor intercoolers with v band bov mount on side of ic, like the full race proam/prostreet backdoor intercoolers?
Old Jan 25, 2009 | 05:27 AM
RedneckRicer's Avatar
Might wanna check out Forge Intercoolers there kinda expensive as well but perform nicely. Also SRT-4's have dual backdoor intercoolers.
Old Jan 25, 2009 | 05:50 AM
96 GSR-T's Avatar
When you do a dual backdoor you have to hack up your radiator support, you have to shift your radiator to the middle of your car which if you dont have a topmount the fitment can be tight if not impossible, I certainly couldnt do it with my ramhorn.
I know T1 could make one for you, and FR might even sell one currently.
You can also run your piping under the front frame and then up by your tranny and not through the "hole", that is how I use to have mine.
hmmmm. well how is that short cut done/? with dual backdoor?
Old Jan 25, 2009 | 05:51 AM
cuz i'm trying to shorten the ic piping length for better spool time.
Old Jan 25, 2009 | 05:52 AM
someone who has done this shortcut can u post of pics of how its done or what u did?
Old Jan 25, 2009 | 06:23 AM
t57b18's Avatar
i had a custom daul back door ic make for my hatch and i had to cut some metal out of the coresupport but i only had cold side pipeing to worry about my turbo went strait to the ic .pm me if you want the number of the guy who make mine and i can send you some pics of my setup if you would like ..
Old Jan 25, 2009 | 06:31 AM
srmofo's Avatar
the results will be minimal if any at all, if you want to reduce spool time then you should install a properly sized turbo and intercooler for your application....reducing the charge pipe length by a 2foot or so isnt going to do much......what diamter are you using now? unless you are running big power levels you shouldnt be above 2.5
Old Jan 25, 2009 | 06:34 AM
b20beast83's Avatar
in 4 pics
Old Jan 25, 2009 | 06:35 AM
yeah i know it won't be too big of a difference, but still i think it looks way cleaner with the shortcut. t57b18 if u could post a pic on here it would be great.
Old Jan 25, 2009 | 06:46 AM
https://honda-tech.com/forums/showth...=dual+backdoor
Old Jan 25, 2009 | 08:27 AM
srmofo's Avatar
well if your going for looks thats one thing, but performance increases are another story, good luck on whatever you decide
Old Jan 25, 2009 | 10:17 AM
HiProfile's Avatar
One thing to note, shorter piping really doesn't decrease spool RPM much. It decreases transient boost response, but only by a fraction of a second. That benifit is reduced the bigger the turbo & bigger the motor.
The short explaination is your charge piping isn't really what has to fill up with pressure. Its your turbo that has to start blowing more than 1x the amount of air the engine consumes at that given RPM. Think of the engine as a huge leak in the charge pipe - you have to overcome that leak before you even have to worry about filling the piping. FYI it takes a b16 1/4 of a second to cycle (completely empty) a long 2.5" charge pipe setup at 3500rpm.
As far as spool RPM is concerned, it mainly how much energy you shoot into the turbine, and how much energy it needs to accellerate the turbine & compressor wheels. In a world w/o inertia, a large compressor wheel would spool faster, since it 'bites' 2-3x the atmosphere per revolution. Its the inertia that reverses this, as it accellerates much slower.
Old Jan 25, 2009 | 10:29 AM
TheShodan's Avatar
Moderator
^^ Kudos. Nicely explained.
Old Jan 25, 2009 | 01:40 PM
Bailhatch's Avatar
yeah, saving a couple feet is not a good trade off in this case. You end up adding more turbulence having the air enter and exit your endtanks 90 to the flow of the core. Good flow is more important, espicially on the outlet side since you already cooled the air down.
Old Jan 25, 2009 | 04:57 PM
blinx9900's Avatar
Makes sense, if it was as simple as the shortest path was best then log manifolds would be king.
Old Jan 26, 2009 | 10:40 PM
i'm looking for good backdoors, or the intercooler like the full race one.
Old Jan 27, 2009 | 03:38 PM
srmofo's Avatar
then just get a full-race one. you know its tested to perform well so you wont be dissapointed
ashtons300zx
Dec 13, 2011 10:12 PM
Jon at Titan
May 17, 2007 08:58 AM
ferio 95
Dec 15, 2005 07:21 AM
