flange
Old Dec 15, 2005 | 07:45 AM
teddy_dc2's Avatar
Default flange
is there suppose to be a flange between the turbo housing and down pipe elbow? my kit doesn't have one and i suspect it's leaking from there, where can i get that flange. (T3/T4)
Old Dec 15, 2005 | 07:49 AM
KeyserSoze's Avatar
Default Re: flange (teddy_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teddy_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">is there suppose to be a flange between the turbo housing and down pipe elbow? my kit doesn't have one and i suspect it's leaking from there, where can i get that flange. (T3/T4)</TD></TR></TABLE>
I assume you are talking about a gasket not a flange......
Many people run w/o those, but you should be able to get them from any turbo shop. They would just need to know which turbine housing you have. GL.
Old Dec 15, 2005 | 08:01 AM
teddy_dc2's Avatar
yes i ment flange. can't seem to find one, does it matter if it leaks? its a t3/t4, exhaust ar .63, .57 trim wheel
Old Dec 15, 2005 | 08:06 AM
teddy_dc2's Avatar
the kit also didn't come with a gasket between the engine and turbo, can i use the stock? or leave none?
Old Dec 15, 2005 | 08:08 AM
KeyserSoze's Avatar
Default Re: (teddy_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teddy_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">yes i ment flange. can't seem to find one, does it matter if it leaks? its a t3/t4, exhaust ar .63, .57 trim wheel</TD></TR></TABLE>
Okay, still confused......do you want a GASKET?? If so just call a turbo shop, or check online http://www.atpturbo.com or http://www.fast-turbo.com (I think that is the site), or http://www.turbocharged.com , or ..............................................
Get my drift?
Old Dec 15, 2005 | 08:24 AM
PM-Performance's Avatar
Default Re: (KeyserSoze)
if you dont have a flange then your problem is a BIG ******* exhaust leak cuz that means the DP is not connected to the turbo at all. lol
You sure you dont mean a gasket
d16civic111
Sep 14, 2006 04:57 PM
saywhat
May 23, 2006 12:05 PM
FastCougar
Welding / Fabrication
Feb 21, 2006 03:33 PM
ham
Aug 28, 2005 06:29 PM
