Intercooler PIPING SIZE
Old Jan 10, 2006 | 06:45 PM
boostdummy's Avatar
Default Intercooler PIPING SIZE
First off, I did search and there really is not a clear answer or dyno #'s to show what works with what power levels. So I thought I would try and get some feed back
I was wondering what Size HOT SIDE intercooler piping you guys recondmend for a 2.0L Motor running a T3/T04e 57 Trim @20+PSI I will be aiming for 350WHP.
I Have 2.5" on the cold side just wondering whats the best tot use on HOT SIDE 2.5" or 2"?
Thanks
Old Jan 12, 2006 | 09:44 AM
Boosted Power's Avatar
2.5" will go you more turbo lag.
2" can do your 350whp.
DSM guys run 2" on the hotside and push over 300whp.
Old Jan 12, 2006 | 09:51 AM
bdavis's Avatar
Default Re: (Boosted Power)
honestly man, you will not be able to tell the difference. do whatever is easiest
Old Jan 12, 2006 | 10:13 AM
emotionisdead's Avatar
Very Emergency!!
Default Re: Intercooler PIPING SIZE (boostdummy)
i just have a stock b16 on 10psi, but i run all 2.5in excpet for a little foot long section of 2" right after the turbine outlet. i used to run all 2.5in but my traction bars and new downpipe made have to use that 2" section. i didn't notice a difference.
Old Jan 12, 2006 | 10:18 AM
beepy's Avatar
Quick math:
2.0 liters / 2 = 1 liter/revolution x 8500 RPM / 60 = 142 liters per second
142 liters x 61 = 8645 CI/second / CSA (2"/2)^2*pi / 12 = 229.31 feet/second.
229.31 feet/second / speed of sound (1185 ft/s for air at 2.5 atm and 120°F)
= Mach 0.19
Therefore the air is incompressible, therefore pipe losses are primarily determined by frictional wall losses, therefore 2" pipe is plenty for your goals.
Interestingly enough, the amount of boost has very little to do with how large of a pipe you need. The two primary factors are RPM and displacement. However, if you have an intake pre-turbo, you must recalculate the mach number based on mass flow at 1 atm. In this case, a 2" intake pipe pre-turbo would undergo velocities of Mach 0.46, which will have significant pipe losses. 3" pipe pre-turbo, however, will drop the Mach number to 0.20, for negligible pipe losses.
The numbers don't lie, but I still think a 3" intake pipe and 2" charge pipes would look funny.
Old Jan 13, 2006 | 06:34 PM
boostdummy's Avatar
thanks anyone else care to share an opinion?
RattyTuned
Feb 2, 2018 01:13 PM
jbell
Nov 15, 2008 12:54 PM
Speed Infliction
Jul 23, 2006 11:13 AM
jonnybravo
Nov 19, 2003 11:49 AM
R6Boy69
Jun 21, 2001 09:42 AM
