3" Piping........
Old Jan 5, 2004 | 05:05 PM
Bulldogg83's Avatar
Default 3" Piping........
So I am going to be running the Precision GT35E with Inline Pro Manifold and I am planning on keeping my AC. Is there anyone that has pics of a 3" downpipe that will work with AC and not be too restrictive? Other option is just do a 2.5" to 3" off of the housing....
Old Jan 5, 2004 | 06:22 PM
espanol's Avatar
Default Re: 3" Piping........ (Bulldogg83)
if you're worried about a/c then get the full-race manifold that is compatible w/ a/c. ..even if your not worried about a/c get the full-race manifold..you here that kids.full-race kicks ***!!
Old Jan 5, 2004 | 06:28 PM
Bulldogg83's Avatar
Default Re: 3" Piping........ (espanol)
I don't want some ram looking thing under my hood!
j/k
I would run the full race that is compatible, but from pictures that I've seen it doesn't look like there is much clearance between the turbo and the AC condensor which I think would become a problem at a later time....
Old Jan 5, 2004 | 06:32 PM
tommyten's Avatar
why not do a cheeze-froger set-up?
Old Jan 5, 2004 | 06:39 PM
Ben Huynh's Avatar
Easiest way to do it is to go from 2.5"-3.0". You can go to 3" from the turbine but it's a lot of welding labor and more trouble than it's worth.
Old Jan 5, 2004 | 06:47 PM
Bulldogg83's Avatar
Default Re: 3" Piping........ (hatchling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling &raquo;</TD></TR><TR><TD CLASS="quote">why not do a cheeze-froger set-up? </TD></TR></TABLE>
got any pics?
Old Jan 5, 2004 | 07:37 PM
espanol's Avatar
why care about a/c when you can have a 3 inch d/p.
Old Jan 5, 2004 | 07:44 PM
quikB18B's Avatar
If you want to make a ton of power, sometimes you have to sacrifice. I love my a/c but im also not looking to make as much power as you. By the looks of your setup it seems as if your going all out, so i would buy a beater and just ditch the a/c.
I mean a beater will come in handy
Old Jan 5, 2004 | 07:45 PM
SiRkid's Avatar
is the precision a 5 bolt exh housing?
if so your good to go.
4 bolt..youll have to say bye bye to you a/c since youll most likley have to turn the comp side to the drivers side(with a to4s cover)
Old Jan 5, 2004 | 07:48 PM
alpha's Avatar
Full Race has a manifold that allows you to use a 3.00" downpipe.
Old Jan 5, 2004 | 10:34 PM
Bulldogg83's Avatar
Default Re: 3" Piping........ (SiRkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid &raquo;</TD></TR><TR><TD CLASS="quote">is the precision a 5 bolt exh housing?
4 bolt..youll have to say bye bye to you a/c since youll most likley have to turn the comp side to the drivers side(with a to4s cover)</TD></TR></TABLE>
Yes it is the 5 bolt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">Full Race has a manifold that allows you to use a 3.00" downpipe.</TD></TR></TABLE>
yeah I know that...
Not ditching the AC....ditched the AC on last setup and wanting to keep it on the new one....
Old Jan 5, 2004 | 11:40 PM
B18bEK's Avatar
to a/c
to 3" downpipes and power
and look on the bright side, if you start with a 3" downpipe and you dont' like it, just hit a city tittie and bend it a little thats what i did!
Old Jan 6, 2004 | 12:33 AM
DIRep972's Avatar
Smarter than you
Brian, I know some tricks that allow you to run a true 3" downpipe on a B series engine w/ T3 5bolt turbine housing and Inline pro manifold and KEEP A/C. Let me know if u wanna hear the ideas.
Old Jan 6, 2004 | 08:03 AM
Bulldogg83's Avatar
Default Re: 3" Piping........ (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">Brian, I know some tricks that allow you to run a true 3" downpipe on a B series engine w/ T3 5bolt turbine housing and Inline pro manifold and KEEP A/C. Let me know if u wanna hear the ideas. </TD></TR></TABLE>
you da man! pm sent
Old Jan 6, 2004 | 08:25 AM
quikB18B's Avatar
Double121 just hacked at his existing shitty donwpipe and cut and rewleded it to run a full 3" with a/c and revhard manfiold. The angle isn't that great but it has plenty of clearance, i think he could have even left another 1" to have a better angle but whast done is done.
Im sure Chris has a few tricks up his sleeve though
Old Jan 6, 2004 | 08:28 AM
Bulldogg83's Avatar
Default Re: 3" Piping........ (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">
Im sure Chris has a few tricks up his sleeve though</TD></TR></TABLE>
He usually always does!
Old Jan 6, 2004 | 08:48 AM
rocket256's Avatar
I fill your pain on wanting to keep a/c. I look at it like this. It gets to hot where I live to be trying to drive around with no a/c. I went Rev Hard manifold.
Old Jan 6, 2004 | 08:52 AM
Bulldogg83's Avatar
Default Re: 3" Piping........ (rocket256)
I drove around last year without AC and I could deal with it, but then when we took the turbo kit off and I put AC back on I forgot what I had been missing....I want to be able to be racing some foo with da windows up looking over at him as he is breaking a sweat and I'm just chillin
Old Jan 6, 2004 | 09:09 AM
B18bEK's Avatar
just get one of those fans that the bus drivers use that mount to the vents
Old Jan 6, 2004 | 10:12 AM
4U2NV's Avatar
How much is that gonna cost him...?
Brian, who cares about A/C... You work during the day, and at night you can roll with the windows down... Besides, last time I checked, 3" dp makes more power than a/c...
Old Jan 6, 2004 | 10:19 AM
rocket256's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulldogg83 &raquo;</TD></TR><TR><TD CLASS="quote">I drove around last year without AC and I could deal with it, but then when we took the turbo kit off and I put AC back on I forgot what I had been missing....I want to be able to be racing some foo with da windows up looking over at him as he is breaking a sweat and I'm just chillin </TD></TR></TABLE>
I agree 100%
Old Jan 6, 2004 | 10:28 AM
Bulldogg83's Avatar
Default Re: 3" Piping........ (4U2NV)
we'll see what insight chris has and then we will go from there
Old Jan 6, 2004 | 11:45 AM
AVATAR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4U2NV &raquo;</TD></TR><TR><TD CLASS="quote">
Besides, last time I checked, 3" dp makes more power than a/c... </TD></TR></TABLE>
WErd to your motha ! ! !
Old Jan 6, 2004 | 12:06 PM
Bulldogg83's Avatar
Default Re: 3" Piping........ (AVATAR)
Eureka!!!!
Just got a PM from Chris (DiRep972) explaining on how I can run a 3" DP without losing my AC.....going to give it a shot and if it works then I will do a write up on it....
to Chris
Old Jan 6, 2004 | 12:20 PM
txhatch's Avatar
Sounds wicked.
