Intercooler piping....
Old Sep 17, 2005 | 12:54 PM
  #26
KeyserSoze's Avatar
Default Re: Intercooler piping.... (tony1)
That sounds very reasonable, however, if you engine can outflow the piping wouldn't the piping then be a hinderance(sp?)?
For example my engine @ pr = 2.02 should (theoretically) flow ~551cfm, if later I wanted to boost 18psi rather than the 15psi I plan on then the 2" piping would be a restriction since a pr = 2.22 on my engine gives me ~607cfm, right? Or am I looking at this all wrong.
Old Sep 17, 2005 | 12:57 PM
  #27
tony1's Avatar
Default Re: Intercooler piping.... (KeyserSoze)
Exactly, too small you will loose power, too big there will be a minute difference in spool, very minute. I just finished reading that other post and "turncoat" is right.
Old Sep 17, 2005 | 01:09 PM
  #28
KeyserSoze's Avatar
Thanks for the clarification Tony, in my original posts I was just trying to get the author to consider that the pipe size might be a restriction if he was looking for higher flows than the piping could allow. I think that I might just go with the 2" from comp to tb, because my desired max hp will only be ~400hp. Also, this is a very good price for ic piping.
Old Sep 17, 2005 | 02:22 PM
  #29
tony1's Avatar
2" intercooler piping is a bit small for 400hp. I'm not saying you can't do it, but it will be a restriction. If you want to make your stuff the right size, i've got aluminum bends pretty cheap, in all sizes. You'll have to make it yourself though, don't know if that's a possibility or not. For 400hp, i'd do 2.25" to the ic and 2.5" to the t/b, at least. Again, no downside to going too big, the difference in lag will not even be noticable.
Old Sep 17, 2005 | 04:50 PM
  #30
KeyserSoze's Avatar
Thanks for the tip, appreciate it. I'll deffinately follow your advice.
I wish I could make the piping myself, but we only have one of the cheaper miller tig machines and a crappy lil' wire feed mig. I would need a better tig even though we did just get some helium in
Old Sep 17, 2005 | 04:52 PM
  #31
tony1's Avatar
A cheap miller tig should weld these fine, you only need 100amps output or so for thin aluminum like this.
Old Sep 17, 2005 | 05:02 PM
  #32
KeyserSoze's Avatar
The welders we have here say that our tig is kinda crappy to heli-arc weld with, but maybe I'll c if I can round up some alum fill and get them to help me (I am a HORRIBLE welder).
Unfortunately, I don't know exactly what bends/lengths of tubing I need, looks to me like 6 90's, 1 45 (or another 90) and maybe a ~7' straight tube. What are your prices on the bends and straight tubing??
I already have mild steel ic tubing, but figured that aluminum would b better.
ghettochild
Jul 11, 2004 09:42 AM
TurBoXBirD16
May 29, 2002 10:44 PM
