Intercooler efficiency...
Old Oct 25, 2001 | 06:00 PM
shingles's Avatar
Default Intercooler efficiency...
I am thinking about getting spearco to make me a custom sized intercooler... it'd be 3" thick by 6" tall by 24" long. How efficient would something this size be? It's about the same size as the 2-209 core. Would something like this be good enough for say 15psi?
thanks,
-Shing
Old Oct 25, 2001 | 10:43 PM
MiraiZ's Avatar
Default Re: Intercooler efficiency... (shingles)
thats pretty good...you don't want anything too thick, 'cause your pressure will drop too much ...3" is good enough...and the longer it is(in length) the better the efficiency, so you want the longest possible one that will fit on your car.
Old Oct 25, 2001 | 10:52 PM
Ben Huynh's Avatar
Default Re: Intercooler efficiency... (MiraiZ)
I agree. When it comes to ATA intercoolers, it's the length that matters, not the girth.
Old Oct 25, 2001 | 11:19 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Intercooler efficiency... (ben@importparts.com)
You said Girth..
Old Oct 25, 2001 | 11:32 PM
dbman96's Avatar
New User
Default Re: Intercooler efficiency... (Arturbo)
Length = efficiency in heat transfer but also = increased pressure drop, which means turbo has to produce more boost to make equal boost when it gets to the manifold. More boost from turbo = more heat to dissipate, so it would be interesting to see where the "break even" point is in compromise between intercooler efficiency and head drop.
Old Oct 26, 2001 | 12:03 AM
paulzy's Avatar
Default Re: Intercooler efficiency... (dbman96)
I thought that length doesn't really matter. I was always told that the more tubes(rows) it has, the more eefiecient it will be. AS for example: a top-bottom of 18x6x3 will have the same efficiency if not better than a side to side of 24x8x3. DOn't quote me on these core sizes, I'm just throwing numbers around, please correct me if I'm wrong.
Old Oct 26, 2001 | 11:30 AM
shingles's Avatar
So if thickness doesn't matter that much, would one even want to go down to say 2.5"?
-Shing
Old Oct 26, 2001 | 12:01 PM
Buckkaaaa!!'s Avatar
New User
i have a spearco, all i know is that right after i run her hard, one pipe is cold, one is hot so i'm satisfied
Old Oct 26, 2001 | 03:58 PM
Ben Huynh's Avatar
2.5" is fine. It will also allow you to get your bumper cover back on without a fight.
92integraVTECgsr
Jul 1, 2008 09:12 PM
Arsenal
Oct 13, 2003 06:55 AM
vtec.dc2
Dec 15, 2002 07:41 PM
grnsol
Feb 20, 2002 10:23 AM
prjctCIVIC
Jun 26, 2001 03:29 PM
