Intercooled VS Non-Intercooled
Old Jan 8, 2003 | 02:59 PM
RiceBurner98SC's Avatar
Default Intercooled VS Non-Intercooled
After deciding which route I am going to take with the addition of a turbo kit, I wanted to know if I could run a kit like the GReddy kit on my Integra at around 6-7 psi WITHOUT an intercooler at first, then IF I decided to bump up to 8+ PSI, I could add the intercooler down the road. More than likely I would add it anyhow to produce more hp at the same amount of boost, but cash flow at first may not permit me to purchase the intercooler at time of kit purchase. OR do I HAVE to have an intercooler in order to run low boost so I dont fry any of my internals. I know on the SOHC civics at 6-7 psi, an intercooler isnt needed.
Old Jan 8, 2003 | 03:04 PM
MiraiZ's Avatar
Default Re: Intercooled VS Non-Intercooled (RiceBurner98SC)
IC's aren't only for adding HP, its also for reducing detonation....food for thought
Old Jan 9, 2003 | 04:59 PM
Default Re: Intercooled VS Non-Intercooled (MiraiZ)
Yeah, I figured out that much. Thanks for the info, but considering Im going to start out with a standalone system, I should be good either way I choose. Thanks again.
Old Jan 9, 2003 | 05:08 PM
MayhemSi's Avatar
A standalone cannot compensate for a hot charge from a turbo with no IC. Buy the IC and save yourself the grief later.
Old Jan 9, 2003 | 07:14 PM
SOHC_MShue's Avatar
Default Re: Intercooled VS Non-Intercooled (MayhemSi)
Do you guys think it would be ok to run the greddy kit on a 98 sohc vtec without an ic at first? i'm thinking about doing that until i get the money for an ic
Old Jan 9, 2003 | 08:37 PM
DA MUGEN 1's Avatar
Default Re: Intercooled VS Non-Intercooled (98exShifter)
Not advisable
Old Jan 9, 2003 | 10:17 PM
BudaKai's Avatar
Default Re: Intercooled VS Non-Intercooled (DA MUGEN 1)
By the kit put it in the closet, and forget about it till you can afford the I/C.
rustydusty1717
Apr 19, 2008 05:47 PM
Arsenal
Oct 13, 2003 06:55 AM
ggangtong81
Oct 12, 2003 08:13 PM
SOHC_MShue
Mar 21, 2003 01:50 PM
boipika
Feb 26, 2002 10:16 AM
