Integra Turbo Setup
Old Dec 16, 2007 | 06:20 PM
trepteg's Avatar
Default Integra Turbo Setup
hi guys !
I have some questions about a turbo setup
I want to upgrade my 95' integra with a garrett t3 turbocharger for the 2009 summer .. but for this summer , I maybe want to install a little turbo to be used to drive a turbo car , begin by a low budget setup !
I thinked about a Eagle Talon stock turbocharger .. or something like this .. it is a good idea ? just for this summer
Setup :
- Talon turbocharger
- DSM 450 injectors
- FMIC
- HKS SSQV B.O.V
- Manifold ? what kind I should use for a low boost application
- Wastegate ? internal , external ?
- Catback
I just want some informations before be involved in a turbo project ..
tell me the parts that it will miss
and what are the modifications I have to do with a DSM turbo ? to make it fit
thanks !
Old Dec 17, 2007 | 12:10 PM
TheShodan's Avatar
Moderator
Default Re: Integra Turbo Setup (trepteg)
You will make more work for yourself trying to add a smaller non-fitting turbocharger than to just be patient and do it right the first time. You'll easily need to retune entirely b/w turbochargers, not to mention the work refabricated or adjusting your manifold to fit your newer turbocharger.
Save, look, research. Your car is not a DSM, stop trying to make it act like one.
There are plenty of setups here that with a bit of patience and a few more dollars will make your setup more reliable, more fun, and more functional.
Old Dec 17, 2007 | 02:02 PM
Schister66's Avatar
Man U FTW
^^x2
A 14b is not going to work well on your stock GSR. Granted, it is a turbo and it will do what it is designed to do, but the fact is, there are a lot of better options out there for you. If you're looking to do something cheap, get a simple T3 log, a used T3 Super60 and add the rest from there...
Old Dec 17, 2007 | 05:36 PM
trepteg's Avatar
Default Re: (Schister66)
thanks
I think I'll wait to the next winter to buy a garett T3 turbo setup
Old Dec 17, 2007 | 06:01 PM
m R g S r's Avatar
if you're stuck on grabbing something from a junkyard grab a stock evo 8 turbo.....just the twin scroll mani may be expensive to make. . .
Old Dec 17, 2007 | 06:13 PM
Schister66's Avatar
Man U FTW
^^you've got a point my friend...that's one of the good junkyard turbos
akdrag
Jul 6, 2009 07:27 PM
jxhxb
Sep 30, 2007 03:59 PM
ptsiu
Oct 26, 2003 02:30 AM
Greg123
Dec 6, 2002 05:28 PM
Charles B.
Jan 29, 2002 05:55 PM
