integra oil feed line? help!
Old Sep 28, 2003 | 01:51 AM
bumsta217's Avatar
Default integra oil feed line? help!
hey wassup guys. I was tryin to install my turbo today on my 95 integra. I was tryin to put in the fittin for the oil feed and i guess it wont go in... im assumin i stripped it? becuz now the stock oil sensor wont go in.... what do i do!!!?? help!
Old Sep 28, 2003 | 06:28 AM
redtegger03's Avatar
Default Re: integra oil feed line? help! (bumsta217)
where did you get the feed line from? the fitting that needs to go into the block is a bpst fitting not npt, that may be your problem. flamenco-t should be able to hook you up woth the right fittings, he works wonders with oil lines and super fast service.
Old Sep 28, 2003 | 08:13 AM
Flamenco-T's Avatar
Default Re: integra oil feed line? help! (redtegger03)
Thanks.
try to put the sensor back in slowly and make sure it is on a straight path. If that doesn't help, email me to stan@fast-turbo.com or hit me up on AIM, adhi77
or IM me here.
I'll help you any way I can.
stan
Old Sep 28, 2003 | 08:27 AM
Ri5e's Avatar
Default Re: integra oil feed line? help! (Flamenco-T)
If it's stripped, what you can do is rethread it to a bigger diameter and use an adapter peice to convert it from the big diameter to the stock one.
Or you can have someone weld it up and retap. Only problem is that you might get metal shavings in your oiling system.
Old Sep 28, 2003 | 10:39 AM
71 mgb's Avatar
is its striped u can tap it just take the thred size and pattern u want(on a bolt) take a hach saw and cut 3 or so lines in it a mm or 2 deep, then thred it back in... it will make new threds... this is how to make a getto tap... or u can go buy the real thing
hope this helps
Old Sep 28, 2003 | 07:55 PM
bumsta217's Avatar
Default Re: integra oil feed line? help! (71 mgb)
thanks a lot! guys appreicaite the help
ÁrniMkv
Feb 10, 2012 07:02 AM
omghiii
Aug 24, 2008 08:18 PM
reXem
Jul 8, 2002 06:31 AM
