integra gsr head
Old Aug 22, 2011 | 12:39 PM
MurtazaDSM's Avatar
Default integra gsr head
My head took a **** on me and now its time to rebuild. I have a turbo kit laying around and I am planning on putting it on. I am wondering what are some good set ups for a gsr head going boost because I know the block can handle 300hp and im not going higher than that. thanks
Old Aug 22, 2011 | 12:41 PM
SLIM NOTHING's Avatar
Default Re: integra gsr head
stock gsr head is sufficant.. a stock gsr head can produce 800hp with the right setup. 300hp isnt that much save your money on the tune and fuel area
Old Aug 22, 2011 | 12:52 PM
MurtazaDSM's Avatar
I meant im going to rebuild the head regardless or should I just throw on a b16 head wich is better for boost or should I rebuild the current head with oem parts or aftermarket
Old Aug 22, 2011 | 12:57 PM
well if you are on a budget see which way is cheaper. id rebuild with most oem parts and prolly some type r cams and springs since they will be out of the head. b16 head would be fine also but the cams are smaller then that gsr.
Old Jan 12, 2012 | 02:12 PM
MurtazaDSM's Avatar
bringing back this thread since I dont want to start another one but I took the head off my car today and have I have 4 leaking valves from the exhaust side I sprayed carb cleaner and it leaked through, so I took my head to the machine shop and the guy said that he will resurface the head and grind the valves down. I was curious and was wondering can he just reuse the other good valves and for the valves that are leaking do I need to replace them or can he just ground them down to make a tight seal. He told me to only bring him valve seals. I read some where that shaving the head should be the last resort when he says he will resurface the head is he going to shave it?
MurtazaDSM's Avatar
also can I use supertech valve seals or should I got with oem the car is going to be boosted after I break it in
Old Jan 12, 2012 | 02:49 PM
komat's Avatar
oem valve seals
i would replace the leaking valves and get them all lapped
Old Jan 12, 2012 | 02:56 PM
greyEG's Avatar
why not replace all of them?
Old Jan 12, 2012 | 04:55 PM
komat's Avatar
well not sure what his budget was
Old Jan 12, 2012 | 05:48 PM
MurtazaDSM's Avatar
OK thanks and OK I will tell them to lap the valves but he told me they will pressure check also
Old Jan 15, 2012 | 01:33 AM
MurtazaDSM's Avatar
so i just ordered a new timing belt,tensioner,water pump,dowel pins for head and complete cylinder head gaskit kit is there anyting im missing or should replace while im at it, do I need to replace main seal
Old Jan 17, 2012 | 12:42 AM
MurtazaDSM's Avatar
heres a pic of the pisons with the head off
hialeahzbg
16
Aug 1, 2006 10:57 PM
ninjaturtle1023
Jul 26, 2004 06:32 AM
Luserkid
Mar 8, 2004 09:51 AM
blu2ksi
Nov 7, 2003 09:03 AM
underpressure02
Dec 20, 2002 06:17 PM
