intank pump w/ fmu a no no?
Location: gravity rides everything...everything will fall, se GA/ne FL
1 Post
i guess this was addressed somewhere. i heard it will lean out. does this mean the factory pump will work better and my purchase for the 255 intank was a waste? then do i need to use an inline or not? i have 310 injectors if they mean anything in this equation.
Re: intank pump w/ fmu a no no? (loturbohybrideg)
Which pump did ya get? As long as you get a high pressure 255 you should be fine at somewhat reasonable boost levels.
1 Post
Re: intank pump w/ fmu a no no? (mplex2000)
it's the holley. i heard bosch was the one to get but too late for that. i don't know if it's high pressure, i assume it is? and yeah, i won't be boosting more than 7-8 lbs. it peaks now at 6 and that is plenty for my fully gutted hatch. are those levels ok? do i only need to worry about that problem on higher boost app's? thanks for any more info.
KevronsEG
07-31-2002 07:09 PM
