Intake as a charge pipe?
Old Apr 26, 2004 | 05:56 PM
MooreBoost's Avatar
Default Intake as a charge pipe?
While researching homemadeturbo I found a guy who used an ebay intake as a charge pipe. It looked good, but I was just curious to how it would perform? I assume it would be fine, but I just want to make sure.
Specifically, I was going to do this with a 91 hatch, however with the battery the way it is intakes are made to snake around it. I planned to move the battery to the rear so is there any other model intake I could use that would go straight down into the fender?
He aslo used an OBX BOV, he said it worked fine, does anyone have any experiance with these, or any cheap aftermarket BOVs for that matter?
Old Apr 26, 2004 | 06:18 PM
00b18b's Avatar
Default Re: Intake as a charge pipe? (tegunderpressure)
i dont see why it wouldnt work..just weld the nipple fitting
Old Apr 26, 2004 | 07:40 PM
incogNitto's Avatar
Default Re: Intake as a charge pipe? (00b18b)
Don't even weld the nipple fitting. Use that as a vacuum source for your wastegate. Tial instructions prefer a nipple close to the throttle body so that works out perfectly. I like it better than tapping the compressor housing because it gets a reading that accounts for pressure drop across the intercooler.
Old Apr 27, 2004 | 07:25 AM
MooreBoost's Avatar
Default Re: Intake as a charge pipe? (incogNitto)
Anymore opinions?
I was also considering the TurboXS Type H, anyone use that?
Old Apr 27, 2004 | 07:28 AM
TheShodan's Avatar
Moderator
We ran out of piping on one of our projects and used an intake that wasn't being sold as one of the charge pipes w/ a TIAL BOV, and it works great. Just make sure you have the couplings to go with it.
Old Apr 27, 2004 | 07:31 AM
ForceThis!'s Avatar
HKS SSQV, one of the best choices out there for a lot of reasons, other than it being a pull type
Old Apr 27, 2004 | 07:33 AM
MooreBoost's Avatar
Default Re: (TheShodan)
Ok, Ill probably get an ebay intake and give it a shot.
The D series hatchback intakes do "snake" around the battery, do you think that could be a problem?
Old Apr 27, 2004 | 07:56 AM
Pikachu's Avatar
https://honda-tech.com/zerothread?id=836874
I used an aem cai and chopped it up to use as the charge pipe. Works pretty good.
Old Apr 27, 2004 | 08:29 AM
tegasaurus's Avatar
Default Re: (Pikachu)
i used my injen CAI as a charge pipe... worked damn good
everyone loves pictures
Old Apr 27, 2004 | 09:14 AM
G
sh!t happens.
Default Re: (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">i used my injen CAI as a charge pipe... worked damn good
everyone loves pictures</TD></TR></TABLE>
did the welds do good on the injen intake? i thought u could weld on the injen intakes..
Old Apr 27, 2004 | 09:30 AM
MikeMAN's Avatar
Default Re: (G"UNIT)
you can weld any 2 like metals together.
mike
Old Apr 27, 2004 | 09:39 AM
USDM 4G VTEC's Avatar
i just got done doing my charge pipes
i have a 90 HB so it will be just like waht u need
yes u can use intakes, but if its like my weapon R wich is 3 in is going to drop the boost pressure
AEM or any other that are like 2.25 or 2.5 will work
but get back to me and ill show u how it looks and how i did it to keep the batt there
Old Apr 27, 2004 | 10:03 AM
Finest's Avatar
Default Re: Intake as a charge pipe? (USDM 4G VTEC)
A ~$200-250 CAI hacked up as a charge pipe isn't really cheap per "homemade turbo" standards...but if it's free, then by all means go for it!
Old Apr 27, 2004 | 10:31 AM
Pikachu's Avatar
Mine was free. If it wasn't I would have bought an ebay cai and used that.
Old Apr 27, 2004 | 10:38 AM
m R g S r's Avatar
I used one on my turbo setup with the gsr manifold. Now I have a venom intake so I plan on using the integra LS cai that I ordered off of ebay. Here is a pic of my old setup:
Old Apr 27, 2004 | 11:38 AM
tegasaurus's Avatar
Default Re: (m R g S r)
mine was free...
i had the aluminum greddy type S flange tig welded onto the pipe; worked, held and sealed perfectly
AllMotorMark
Jan 29, 2006 08:08 PM
elpiar
Sep 27, 2005 01:38 PM
civic_driver
Aug 19, 2005 08:09 PM
turbotypeR@SPEC
Aug 29, 2003 05:05 PM
wm5holla
Apr 4, 2003 01:58 PM
