connecting downpipe to cat question.
Old Apr 20, 2004 | 07:01 PM
vietjdmboi's Avatar
Default connecting downpipe to cat question.
what did you guys use to connect it? bolt with a spring and nut or just bolt and nut. this is for a 2.5'' 2 bolt flange. where can i purchase the spring set up if needed. or what do you recommend. thankz
p.s i will also have a flex pipe on the downpipe
Old Apr 27, 2004 | 11:48 AM
dRo15's Avatar
Default Re: connecting downpipe to cat question. (vietjdmboi)
you should be able to buy the springs from the dealer...you do use the springs or else you'll end up having an exhaust leak...
FuriousGeorge
Sep 4, 2004 08:24 AM
spoon23_JDizM AkA SpOoN20
Dec 1, 2003 09:32 AM
ImAcracker
Jan 30, 2003 01:47 PM
