Insulated Gaskets with boost
Old Dec 15, 2003 | 08:11 PM
camp1320.com's Avatar
Default Insulated Gaskets with boost
There are alot of question on why some people dont run Insulated gaskets on hi boost appl.? Take a look at these new gaskets made by PRO FAB.These gaskets will take BOOST wihout leaking or melting problems. They are made out of G10 PHENOMIC.?? i think thats how you spell it?? Top fuel dragsters us these supposely?? anyone have any ideas
PRO FAB Gaskets and Hondata/AN-R gaskets
This is what happenes over a long period of time. The plastic warps and melts with fuel and heat.
I dont think anyone was aware of this situation until now.[/B] .
With these gaskets you dont need to cut, shave, clean, modify, port, drill, or any work,simply bolt on and fire up.
Modified by camp1320.com at 9:37 PM 12/15/2003
Old Dec 15, 2003 | 08:17 PM
B18Flip's Avatar
Default Re: Insulated Gaskets with boost (camp1320.com)
good info, thanks tom
falcongsr's Avatar
What is this crap?
i think the word is phenolic.
basically its a paper/glue product that has good thermal insulation properties.
Old Dec 15, 2003 | 08:21 PM
Default Re: Insulated Gaskets with boost (falconGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR &raquo;</TD></TR><TR><TD CLASS="quote">i think the word is phenolic.
Thanks Falcon, Thats what it was. What do you guys think?? MAKE OR BREAK.??
Old Dec 15, 2003 | 08:22 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camp1320.com &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks Falcon, Thats what it was. What do you guys think?? MAKE OR BREAK.?? </TD></TR></TABLE>
Do a comparison dyno with a Hondata gasket.......couldnt hurt
Old Dec 15, 2003 | 08:24 PM
Default Re: Insulated Gaskets with boost (TeStUdO)
Dyno Tunning Will be done after new years at TRACKMASTER DYNO SERVICE. There will be a H-T dyno day with Free dyno tune hours,given away. Working on alot of Stuff to help out H-T members for next season.
Old Dec 15, 2003 | 08:26 PM
falcongsr's Avatar
What is this crap?
i dont know if a dyno would reveal much. i am going to guess the difference in "thermal conductivity" is low between this and the plastic. i always did question how plastics would hold up when sandwiched against the head like that, but i dont have any further info on it.
i am curious as to the cost difference between the phenolic and the plastic gaskets.
Old Dec 15, 2003 | 08:29 PM
Hondata Gaskets $63
AN-R Gaskets $35 poor quaility
Pro Fab Gaskets $65 complete complete with everything you see.
We are going to dyno them but like you said Falcon i dont think the dyno will give us much answers as wee would need to check it with a air temp sensor or something like that?? correct me if im wrong.? Thanks Falcon and everyone else for you inputs.
Old Dec 15, 2003 | 08:32 PM
TeStUdO's Avatar
we would need to check it with a air temp sensor or something like that?? </TD></TR></TABLE>
Yah something to measure the temp change. Ever think about making one for the throttle body as well??
Old Dec 15, 2003 | 08:35 PM
falcongsr's Avatar
What is this crap?
i honestly dont think you're going to be able to measure a difference at all between plastic and phenolic.
the only advantage one might have over the other is how well it lasts over time. need some long term testers.
Old Dec 15, 2003 | 08:36 PM
Let me tell you why we wouldnt need one for the T-Body. If you reroute the coolent lines like Hondata says, the T body will not conduct much heat. Just my thre.ory. Im sure it wouldnt hurt but if its not the exact size it will also casue a lil bit of turblulance. Im sure all motor cars wouldnt like that
Old Dec 15, 2003 | 08:38 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camp1320.com &raquo;</TD></TR><TR><TD CLASS="quote">Let me tell you why we wouldnt need one for the T-Body. If you reroute the coolent lines like Hondata says, the T body will not conduct much heat. Just my thre.ory. Im sure it wouldnt hurt but if its not the exact size it will also casue a lil bit of turblulance. Im sure all motor cars wouldnt like that</TD></TR></TABLE>
Problem with that is when it gets real cold the throttle can stick
Old Dec 15, 2003 | 08:41 PM
falcongsr's Avatar
What is this crap?
and the IACV too. thats why theres coolant running through it.
and it can freeze/stick when the temp is above freezing too. ask anyone who has flown a carbureted private plane.
Old Dec 15, 2003 | 09:04 PM
Where the Hell you guys live.? ALASKA.? We are out here in Cali. No worries about snow. I dont think Texas and FL need to worry about that either.
Old Dec 15, 2003 | 09:43 PM
Saki0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camp1320.com &raquo;</TD></TR><TR><TD CLASS="quote">Where the Hell you guys live.? ALASKA.? We are out here in Cali. No worries about snow. I dont think Texas and FL need to worry about that either. </TD></TR></TABLE>
There are around 15 other states that get snow in the winter months...so its not just alaska that gets snow j/k man no fuss,LOL. Given my situation I wish I had better weather, *currently under 4" of the white stuff* I need to move out of NY, no avoiding it here . Oh well.
EP
Old Dec 15, 2003 | 10:10 PM
FredoSP's Avatar
Default Re: Insulated Gaskets with boost (Saki0)
Yeah Tom we got 15"+ in NYC 2 weekends ago, dont you watch CNN!
- Fred
Old Dec 16, 2003 | 10:15 AM
trackmasters's Avatar
Default Re: Insulated Gaskets with boost (FredoSP)
Luckliy we live in good old southern California. We dont get much snow but we do get quakes once in a while. Camp bring over some gaskets and we will test them out for you.
Old Dec 16, 2003 | 03:58 PM
Snail EG's Avatar
1. the pictured gasket is not an an-r gasket
2. you do not need to cut, shave, clean, modify, port, drill our gaskets, they are direct bolt on
3. our gaskets do not melt.
4. they are not poor quality ("The AN-R race gaskets fit better than the Hondata Race gaskets, so you won't need to modify them (as much - I found a port shoulder section that needed a little grinding). I don't know about the street stuff tho. I've never used those.") at almost half the price of hondatas gasket they are a bargain
quote taken from https://honda-tech.com/zerothread?id=679933
our gasket:
Modified by Snail EG at 7:11 PM 12/16/2003
93b20z
Feb 27, 2009 08:14 AM
camp1320.com
40
Feb 2, 2004 10:36 AM
BlackThorN
Dec 21, 2003 12:51 AM
BoostedD15B7
Aug 8, 2002 12:26 PM
