anyone knows of some sort of electronic device that cut boost after reaching a preset amount ?
sorta like a prevention to boost spiking?
so let's say I set it at 9 psi if it ever spike that high, it'll automatically open the wategate to dump exhaust gas out ...
New User
Re: anyone knows of some sort of electronic device that cut boost after reaching a preset amount ? (
Hondata
It has a boost cut circuit which will cut power if a certain boost pressure is exceeded. It is user definable.
[Modified by VaporTrail, 1:01 AM 2/7/2002]
I was just gonna say Hondata but it looks like John beat me to it
hmm, is this available on any stage with boost option ?
I thought the Apexi AFC-R is also able to prevent boost spiking?
The AVC-R can control boost, but if the wastegate or some other issue is causing boost to spike it can't control it. Hondata just cuts fuel when it senses too much boost...
Dustin
Dustin
Dustin
Dustin
Injecting zero fuel doesn't hurt anything. You get no combustion.. that's what you want.
Dustin
Dustin
It's not electronic, but that's what a pop-off valve is for, to prevent boost spikes.
Yeah, I run one .......You need two things: a msd softtouch rev limiter (or 6 series ignition with this built in), and either a gauge w/ a warning light (and output at warning....like the Greddy gauge) or a pressure switch.
What you do is have the gauge or switch hit a relay that switches between the msd running through the rpm pill or running strait (no resistor).
This method has been working great for me. In addition I will soon be adding a NOS fuel pressure safety switch so I can't pressure drop out on me.
If you want more info on this and wiring schematicpoo poo me up.
Dustin
Dustin
Hondata
New User
blitz dual sbc will reduce boost by x when your preset limit is reached..
Hondata
Damn do I want Hondata..
Dustin
zdyne has one too! i just make that area super rich and no timing! instant boost cut lol
New User
I just let mine spike away.. which it has only done once or twice when my wastegate was hooked up worng... It was moving REALLY fast at 15-18 PSI
Glad my motor's built!
Pythagoras
06-26-2005 01:05 PM
