Installing Walbro fuel pump?
Old Aug 10, 2003 | 01:05 PM
B20LS-T's Avatar
New User
Default Installing Walbro fuel pump?
Do you have to pull the fuel tank to do this? I was reading the Helms and it says you do, is there an easier way around this?
Old Aug 10, 2003 | 01:09 PM
ELESVEE's Avatar
Default Re: Installing Walbro fuel pump? (B20LS-T)
na just take out ur rear seats and it's only a few bolts away. it's very easy to do, search c-speed's site for a step by step
T-sohctec's Avatar
it's under your back seat. pull the seat and it's really easy after that. you just un-bolt the pump and put your new one in.
Old Aug 10, 2003 | 04:09 PM
JustAnotherHonda's Avatar
Default Re: Installing Walbro fuel pump? (T-sohctec)
Loosen the gas cap to relieve some of the pressure in the tank first. Easy safety precaution.
Old Aug 10, 2003 | 04:17 PM
boostedsol's Avatar
Default Re: Installing Walbro fuel pump? (JustAnotherHonda)
Its not too bad at all. You do not have to pull the tank. Just unscrew a couple bolts, pull out the fuel pump, and replace it w/ the walbro intank.
GL.
Old Aug 10, 2003 | 04:24 PM
racinskittle's Avatar
Default Re: Installing Walbro fuel pump? (boostedsol)
comes out from the top. All you have to do is take off the cover. Very easy, very self explanitory.
The bolts can be a bitch sometimes.
I also used a fan just to blow away the fumes, but it's not necessary
Old Aug 10, 2003 | 04:53 PM
SJP0tato's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20LS-T &raquo;</TD></TR><TR><TD CLASS="quote">Do you have to pull the fuel tank to do this? I was reading the Helms and it says you do, is there an easier way around this?</TD></TR></TABLE>
It depends on what year you own. Us 88-91 guys got the shaft on this one. If you're running an ED/EF, you've gotta drop the tank.
meh,
Ryan P.
Old Aug 11, 2003 | 08:10 PM
Blueprint's Avatar
If you have a 88-91civic/crx you must drop the whole gas tank which is a BITCH.. i would just use a inline pump if thats the case. If its a 92-00 civic/delsol/integra take the back seats out and unbolt 6 10mm nuts and pull the pump out sitwch the pump and plug and play.
Old Aug 11, 2003 | 10:02 PM
spooned out's Avatar
just take the bottom back seats off and from there you could get access to the fuel pump by removing the top covers, i think with the walbro pump you can't use the stock rubber bottom piece it will not fit with the new pump, just use a zip tie and tie the pump to the bracket holding the pump
Old Aug 12, 2003 | 01:51 AM
pissedoffsol's Avatar
25 Year Member
Default Re: Installing Walbro fuel pump? (spooned out)
i was told to re-wire the system for the HP pump, as it draws too much current......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
i would highly suggest installing a relay.......
As the walbro pumps draws a hell of alot more current..... And leaving the stock wiring to supply this most likely cause your main relay to fail.
Just look at the stock wiring for the fuel pump its like 22G .... crazy....
thoughts?
Old Aug 12, 2003 | 02:49 AM
Dee's Avatar
Dee
Default Re: Installing Walbro fuel pump? (pissedoffsol)
I have been using GSS342's in my car for two years without any problems. All wiring is stock like the majority of the Honda users.
Old Aug 16, 2003 | 09:23 PM
has anyone tried replacing there stock crx fuel pump? if so is it the same as the civic's and integras?
Old Aug 16, 2003 | 09:25 PM
Happyman's Avatar
Default Re: (spooned out)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooned out &raquo;</TD></TR><TR><TD CLASS="quote">has anyone tried replacing there stock crx fuel pump? if so is it the same as the civic's and integras?</TD></TR></TABLE>
Yup. Pretty much the same location as well.
Old Aug 16, 2003 | 10:56 PM
filthy scarecrow's Avatar
are zip ties fuel proof? i'd use a hose clamp.
tobytigger
Jul 22, 2017 05:02 PM
trooper0641
Jul 13, 2005 08:21 PM
Mike1486
Sep 24, 2004 11:19 AM
cvc323
Oct 31, 2003 08:02 PM
turboZChatch
Sep 25, 2003 04:03 AM
