Inlinepro headgasket on B18C1
Old Apr 29, 2004 | 03:00 PM
Alberto's Avatar
Default Inlinepro headgasket on B18C1
Will it be safe to push 10psi on stock b18c1 with an inlinepro headgasket? Compression should be around 9.0.
Old Apr 29, 2004 | 03:06 PM
B18 CYA's Avatar
Default Re: Inlinepro headgasket on B18C1 (Alberto)
they say 6-8psi on stock internals for a gsr...10 would probably pushing it. I built my internals and am planning on running 14..
Old Apr 29, 2004 | 03:11 PM
Adi Radoncic's Avatar
On Fire!
People have ran 22psi with stock b18c1 longblocks and a inline pro headgasket, so 10psi would be no problem. All you have to make sure of is to keep your afr's on the conservative side.
If you do a search you will find a lot of topics about this so it will get a lot of your questions answered.
Old Apr 29, 2004 | 03:14 PM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alberto &raquo;</TD></TR><TR><TD CLASS="quote">Will it be safe to push 10psi on stock b18c1 with an inlinepro headgasket? Compression should be around 9.0.</TD></TR></TABLE>
Which inline pro one are you talking about?
3mm gasket = 8.30:1
2mm gasket = 8.96:1
1mm gasket = 9.76:1
I'm going to assume it's a 2MM gasket. You'll be fine with 10 psi, as that guy said people have pushed 14+++ psi on a stock gsr block.
Old Apr 29, 2004 | 03:30 PM
Alberto's Avatar
Default Re: Inlinepro headgasket on B18C1 (newgsr just D.T.P)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsr just D.T.P &raquo;</TD></TR><TR><TD CLASS="quote">All you have to make sure of is to keep your afr's on the conservative side. </TD></TR></TABLE>
I'm running vortech fmu as fuel regulator =/.
Old Apr 29, 2004 | 04:38 PM
TurboJesse
Guest
Posts: n/a
Im a fan of their headgasket but please save the $300 and get good management. You can run 10-12psi easily on the stock compression with tuning. I run the headgasket @15psi with hondata.
Wide Open Throttle
Feb 25, 2004 07:27 PM
VTC_CiViC
Oct 20, 2003 05:54 PM
SpeedMonkeyRacing
Mar 10, 2002 12:09 AM
Cyber ITR
Jul 17, 2001 12:51 PM
