Odd injector Question
Old Apr 26, 2004 | 03:19 PM
onePOINTsix's Avatar
Default Odd injector Question
Ok well i finally broke down and bought a new multimeter to mesure the restance on my RX7 injectors. Turns out 2 are Low Imp. and 2 are High Imp. Now my question is can I run 2 Low 2 High without any problems? I'm running OBD0 with a resistor box and i did the MPFI swap so i know the wiring. Thanks for your help
PS. I cant afford another set, thats why i'm wondering this
Old Apr 26, 2004 | 04:11 PM
Default Re: Odd injector Question (Sideout)
b i to tha dubble izzump
Old Apr 26, 2004 | 06:53 PM
11 o'clock bump
Old Apr 26, 2004 | 07:57 PM
bump 4 tomarrow
Old Apr 26, 2004 | 08:03 PM
JonGP4's Avatar
what ECU are you running?
Old Apr 29, 2004 | 03:59 PM
BlueCrxNC's Avatar
It is possible. You just need to add a resistor for each of the Peak and Hold Injectors (essentially the same as adding the injector resistor box which houses the resistors). You'll need to leave the other two (saturated) injectors alone (without the resistor). Sorry I don't know the resistor value.
ECU does NOT matter. It always sends out the same data.
Old Apr 29, 2004 | 04:38 PM
b16ahybrid's Avatar
Default Re: (BlueCrxNC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueCrxNC &raquo;</TD></TR><TR><TD CLASS="quote">It is possible. You just need to add a resistor for each of the Peak and Hold Injectors (essentially the same as adding the injector resistor box which houses the resistors). You'll need to leave the other two (saturated) injectors alone (without the resistor). Sorry I don't know the resistor value.
ECU does NOT matter. It always sends out the same data.</TD></TR></TABLE>
I wouldn't recomend that though, peak hold and saturated injectors have different charactoristics,
HONDA300
17
Aug 8, 2007 06:57 PM
labtec
Jun 11, 2007 07:54 AM
9hatchman4
May 22, 2006 03:57 PM
studmuffinej2k
Feb 5, 2006 07:51 AM
jamartin0519
Apr 4, 2005 12:46 AM
