inlinepro
sup HT ? got a real quick question , i currently have a inline pro turbo manifold in my DA and am in the process of piecing together my kit. so heres my question , what side did you put the exhaust side on ? right now its on the passenger side but im having problems with it clearing my half radiator ( the d/p gets in the way). if i put the compressor side on the passenger side the turbo does not clear the block. i would notch the block but i really dont want to do this if i dont have to. any input is apprecited. btw the turbo is a t3/t04e.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808DB1 »</TD></TR><TR><TD CLASS="quote">sup HT ? got a real quick question , i currently have a inline pro turbo manifold in my DA and am in the process of piecing together my kit. so heres my question , what side did you put the exhaust side on ? right now its on the passenger side but im having problems with it clearing my half radiator ( the d/p gets in the way). if i put the compressor side on the passenger side the turbo does not clear the block. i would notch the block but i really dont want to do this if i dont have to. any input is apprecited. btw the turbo is a t3/t04e. </TD></TR></TABLE>
Which inlinepro manifold ?
If it is a ss t3/t4 a/c compatible manifold, you should have the downpipe on the drivers side.
yup its the ss t3/t4 a/c compatible . the main reason why it does not clear the block is because it has a slight angel on the flange so that the turbo is off set a litle
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">You notch the block a bit so the compressor doesn't hit it on the AC compatible manifolds. Don't even think of fitting a S housing cover on there either, lol.</TD></TR></TABLE>
i was actually thinking about putting a 60-1 with a cast manifold but everyone said 4" inlet is no way gonna fit with a cast manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k »</TD></TR><TR><TD CLASS="quote">
i was actually thinking about putting a 60-1 with a cast manifold but everyone said 4" inlet is no way gonna fit with a cast manifold.</TD></TR></TABLE>
It won't. We have a car we just finished up and originally we tried to fit the S cover on it. We grinded the block down as well as the compressor housing. Just go with the E cover... it fits MUCH better. The block still has to be notched though with the E cover.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cvcrtonv »</TD></TR><TR><TD CLASS="quote">U also have to make sure you have a 5-bolt exhaust housing. </TD></TR></TABLE>
Since when? 4 bolt fits as well.
Since when? 4 bolt fits as well.</TD></TR></TABLE>
I herd this was also false. 4bolt housing does not fit with a cast manifold. it doesn't clear the ac compressor
https://honda-tech.com/zerothread?id=2139340
https://honda-tech.com/zerothread?id=2139340</TD></TR></TABLE>
inlinepro makes a t3 manifold for 4 and 5 bolt housing turbos. so you need to make sure you have the comptibility right. generally 4 bolt turbos have a very difficult time clearing the block on cast manifolds.
inlinepro 5-bolt
inlinepro 4-bolt
images courtesy of http://www.inlinepro.com. see the difference in runners??
EDIT: btw these manifolds are made to work with the compressor on the passenger side. but i have seen them flipped around too.
inlinepro 5-bolt
inlinepro 4-bolt
are you using a 5 bolt turbo and 5 bolt manifold??
if you still need to notch it should only be the webbing or maybe some of the engine code area. shouldnt be a big deal, there is more material there than you think. just dont go crazy. there are probably plenty of threads in the archives about notching as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808DB1 »</TD></TR><TR><TD CLASS="quote">i have the 5 bolt , by the way does notching the block make it lose any of its structural integrity ? im kind of weary notching it </TD></TR></TABLE>
u can notch it no problem. I think most ac manifolds (ram horn style etc) all need notching.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">are you using a 5 bolt turbo and 5 bolt manifold??
if you still need to notch it should only be the webbing or maybe some of the engine code area. shouldnt be a big deal, there is more material there than you think. just dont go crazy. there are probably plenty of threads in the archives about notching as well </TD></TR></TABLE>
yeah im using a 5 bolt turbo and manifold
yeah im using a 5 bolt turbo and manifold</TD></TR></TABLE>
I think you mean a 5 bolt SVO housing using an inline pro manifold that is fitted for the 5 bolt exhaust housing. The manifold -- turbo T3 inlet flange is 4 bolt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">
yes we are refering to the turbine discharge b/c he is worried about notching the block
