inlinepro
Old Jan 27, 2008 | 10:56 PM
808DB1's Avatar
Default inlinepro
sup HT ? got a real quick question , i currently have a inline pro turbo manifold in my DA and am in the process of piecing together my kit. so heres my question , what side did you put the exhaust side on ? right now its on the passenger side but im having problems with it clearing my half radiator ( the d/p gets in the way). if i put the compressor side on the passenger side the turbo does not clear the block. i would notch the block but i really dont want to do this if i dont have to. any input is apprecited. btw the turbo is a t3/t04e.
Old Jan 27, 2008 | 11:30 PM
mtber's Avatar
Default Re: inlinepro (808DB1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808DB1 &raquo;</TD></TR><TR><TD CLASS="quote">sup HT ? got a real quick question , i currently have a inline pro turbo manifold in my DA and am in the process of piecing together my kit. so heres my question , what side did you put the exhaust side on ? right now its on the passenger side but im having problems with it clearing my half radiator ( the d/p gets in the way). if i put the compressor side on the passenger side the turbo does not clear the block. i would notch the block but i really dont want to do this if i dont have to. any input is apprecited. btw the turbo is a t3/t04e. </TD></TR></TABLE>
Which inlinepro manifold ?
If it is a ss t3/t4 a/c compatible manifold, you should have the downpipe on the drivers side.
Old Jan 27, 2008 | 11:47 PM
808DB1's Avatar
yup its the ss t3/t4 a/c compatible . the main reason why it does not clear the block is because it has a slight angel on the flange so that the turbo is off set a litle
Old Jan 28, 2008 | 05:55 AM
PrecisionH23a's Avatar
You notch the block a bit so the compressor doesn't hit it on the AC compatible manifolds. Don't even think of fitting a S housing cover on there either, lol.
Old Jan 29, 2008 | 02:54 AM
integlspwr2k's Avatar
Default Re: inlinepro (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">You notch the block a bit so the compressor doesn't hit it on the AC compatible manifolds. Don't even think of fitting a S housing cover on there either, lol.</TD></TR></TABLE>
i was actually thinking about putting a 60-1 with a cast manifold but everyone said 4" inlet is no way gonna fit with a cast manifold.
Old Jan 29, 2008 | 06:37 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: (808DB1)
Yeah, have you considered notching the block? This often has to be done on AC compatible manifolds.
Old Jan 29, 2008 | 07:55 AM
Default Re: inlinepro (integlspwr2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k &raquo;</TD></TR><TR><TD CLASS="quote">
i was actually thinking about putting a 60-1 with a cast manifold but everyone said 4" inlet is no way gonna fit with a cast manifold.</TD></TR></TABLE>
It won't. We have a car we just finished up and originally we tried to fit the S cover on it. We grinded the block down as well as the compressor housing. Just go with the E cover... it fits MUCH better. The block still has to be notched though with the E cover.
Old Jan 29, 2008 | 08:14 AM
cvcrtonv's Avatar
U also have to make sure you have a 5-bolt exhaust housing.
Old Jan 29, 2008 | 08:47 AM
Default Re: (cvcrtonv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cvcrtonv &raquo;</TD></TR><TR><TD CLASS="quote">U also have to make sure you have a 5-bolt exhaust housing. </TD></TR></TABLE>
Since when? 4 bolt fits as well.
Old Jan 29, 2008 | 10:39 AM
Default Re: (PrecisionH23a)
Since when? 4 bolt fits as well.</TD></TR></TABLE>
I herd this was also false. 4bolt housing does not fit with a cast manifold. it doesn't clear the ac compressor
https://honda-tech.com/zerothread?id=2139340
Old Jan 29, 2008 | 12:16 PM
dpetro1's Avatar
Default Re: (integlspwr2k)
https://honda-tech.com/zerothread?id=2139340</TD></TR></TABLE>
inlinepro makes a t3 manifold for 4 and 5 bolt housing turbos. so you need to make sure you have the comptibility right. generally 4 bolt turbos have a very difficult time clearing the block on cast manifolds.
inlinepro 5-bolt
inlinepro 4-bolt
images courtesy of http://www.inlinepro.com. see the difference in runners??
EDIT: btw these manifolds are made to work with the compressor on the passenger side. but i have seen them flipped around too.
Old Jan 29, 2008 | 12:24 PM
808DB1's Avatar
i have the 5 bolt , by the way does notching the block make it lose any of its structural integrity ? im kind of weary notching it
Old Jan 29, 2008 | 12:29 PM
dpetro1's Avatar
are you using a 5 bolt turbo and 5 bolt manifold??
if you still need to notch it should only be the webbing or maybe some of the engine code area. shouldnt be a big deal, there is more material there than you think. just dont go crazy. there are probably plenty of threads in the archives about notching as well
Old Jan 29, 2008 | 12:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808DB1 &raquo;</TD></TR><TR><TD CLASS="quote">i have the 5 bolt , by the way does notching the block make it lose any of its structural integrity ? im kind of weary notching it </TD></TR></TABLE>
u can notch it no problem. I think most ac manifolds (ram horn style etc) all need notching.
Old Jan 29, 2008 | 12:43 PM
808DB1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">are you using a 5 bolt turbo and 5 bolt manifold??
if you still need to notch it should only be the webbing or maybe some of the engine code area. shouldnt be a big deal, there is more material there than you think. just dont go crazy. there are probably plenty of threads in the archives about notching as well </TD></TR></TABLE>
yeah im using a 5 bolt turbo and manifold
Old Jan 29, 2008 | 12:48 PM
TheShodan's Avatar
Moderator
yeah im using a 5 bolt turbo and manifold</TD></TR></TABLE>
I think you mean a 5 bolt SVO housing using an inline pro manifold that is fitted for the 5 bolt exhaust housing. The manifold -- turbo T3 inlet flange is 4 bolt.
Old Jan 29, 2008 | 12:51 PM
808DB1's Avatar
yeah this is correct , the manifold is a 4 bolt flange. what is SVO ?
Old Jan 29, 2008 | 01:29 PM
dpetro1's Avatar
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">
yes we are refering to the turbine discharge b/c he is worried about notching the block
crick_james
Sep 5, 2008 04:12 AM
Sketch_hs
May 10, 2005 06:12 PM
VASlowTec
Sep 8, 2003 09:29 AM
Boost2NA
Aug 15, 2002 06:22 PM
