inline pumps
not interested in trading gonna keep and use it with the inline if i can
is there ant specific stores online that sell them
[Modified by turbofed EX, 3:37 PM 9/26/2002]
so if i get the inline it should work with 9psi?
inline pump, intank pump, fmu, adj. fpr should all work together with a little tuning
or should i just new injectors
[Modified by turbofed EX, 4:52 PM 9/26/2002]
running lean at only 9 psi ??
I use the exact same pump as you...no problems....are u using the right plugs?...NGK BKRE 7E is what i use...i dont think u need an additional inline
You need an inline if your running an fmu. This topic has been beaten to death. High pressure fmu=need high pressure inline. Yes, bigger injectors and standalone would be a better idea.
