Inline Pump
Old Nov 14, 2002 | 09:03 AM
turbofed EX's Avatar
Default Inline Pump
for all you guys running inline pumps I have a few questions.
Where on the car did you mount the pump?
Is it put inline before or after the FMU?
Did you have to change the 15 amp fuse to a bigger one in the fuse box under the hood?
How did you wire the pump electrically to run?
I just got one today and will be doing the install on Sat. ao just want to make sure I do it right the first time.
thanx for all the help
forgot to mention a 97 civic EX SOHC
[Modified by turbofed EX, 1:12 PM 11/14/2002]
Old Nov 14, 2002 | 09:20 AM
gtcali's Avatar
Default Re: Inline Pump (turbofed EX)
Pump goes somewhere before the fuel rail. Some put it in the engine bay between the filter and the fuel rail. Some put it next to the gas tank.
Use a relay for the fuel pump a search might give you a Pic of how to wire the rely up (thought its been awhile). Skinny - wire to the OG fuel pump sends signal to a relay that sends a 12v signal to inline fuel pump.
FMU goes after the fuel rail on the return line.
Old Nov 14, 2002 | 02:17 PM
Default Re: Inline Pump (gtcali)
ttt
Old Nov 14, 2002 | 02:51 PM
inspyral's Avatar
This was how my relay was setup when I ran an inline:
Thanks to Art for the pic.
Old Nov 15, 2002 | 04:18 AM
Default Re: Inline Pump (inspyral)
were did you get the relay from.
why cant I just tap into the stock relay that is on the car for the stock pump?
Old Nov 15, 2002 | 06:44 AM
inspyral's Avatar
You can get the relay from Radio Shack. You do tap the stock pump relay, but only for the signal wire. The inline pump needs its own relay.
Old Nov 15, 2002 | 06:49 AM
is there a part # for it
Old Nov 15, 2002 | 06:50 AM
where did you get the constant supply from
Old Nov 15, 2002 | 07:17 AM
turbosol's Avatar
The battery.
Old Nov 15, 2002 | 07:32 AM
Default Re: Inline Pump (turbosol)
hot wire straight from the battery, thanks
Old Nov 15, 2002 | 02:37 PM
where did everybody mount their pumps, I can't find any room in the engine bay maybe someone knows something that can help
pleej
Apr 8, 2011 11:06 AM
S2kool
Dec 14, 2008 03:24 AM
civicgsr209
Oct 13, 2004 10:37 PM
Jamison
Jul 11, 2002 12:07 PM
EF8SIR
Mar 19, 2002 05:11 AM
