Inline Pro mani + SC61
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">no.</TD></TR></TABLE>
..and why? Just curious....
the reason you dont need most of the times is that both parts are machined very straight and true. If there were any gaps then tthats when you need to use the gasket most of the time everything is machined true
My manifold is coated, so I use a gasket. Not sure if it would seal w/o it, but for $5, who cares? Just go to the Ford dealer and tell em you need a turbo gasket for a Thunderbird.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">the reason you dont need most of the times is that both parts are machined very straight and true. If there were any gaps then tthats when you need to use the gasket most of the time everything is machined true
Exactly... you shouldnt need a gasket because both the turbo manifold and tubine flange should be machined nearly perfect. This remains the same for the wastegate flange as well. However if you do have a leak, a gasket may be neccessary to make the leak stop.
I ran a gasket betweent the wastegate and manifold and had to remove it because it burned up and created a leak.
cokex
May 13, 2003 05:18 PM
