Inline + Intake Pumps = ?
Old Nov 14, 2001 | 04:37 AM
GSRacer's Avatar
New User
Default Inline + Intank Pumps = ?
i currently have a walboro 255 fi intank pump installed right now. Would i benefit if i used a inline pump in conjunction w/ the walboro? Should i do it?
[Modified by GSRacer, 5:39 AM 11/14/2001]
Old Nov 14, 2001 | 07:26 AM
RGAZ's Avatar
New User
Default Re: Inline + Intank Pumps = ? (GSRacer)
What method of fuel control are you using, FMU or ECU?
Randy
Old Nov 14, 2001 | 07:44 AM
chri5's Avatar
Default Re: Inline + Intank Pumps = ? (RGAZ)
you would benefit if you are currently going over 100 psi. The benefit would be safety.
Old Nov 14, 2001 | 07:49 AM
GSRacer's Avatar
New User
Default Re: Inline + Intank Pumps = ? (Chris_Turbo)
i'm using an FMU
Old Nov 14, 2001 | 07:54 AM
chri5's Avatar
i'm using an FMU
Those walbro pumps will go bad with 100+psi for extended periods. I burned out a 317 running 90psi for 5 months when i had my JRSC. If you have the 342 you'll still burn it out running 110+psi, which I would assume you are doing. You have a Drag with a 12:1 rise rate, right?
Old Nov 14, 2001 | 08:01 AM
GSRacer's Avatar
New User
i'm using an FMU
Yes, i do have a drag. I don't know if they are any different from each other, but i have a Holley FI 255 pump, not a walbro (i typed walbro before by mistake). So, what are you saying? Should I ditch the intank and stick with the airtex inline? Or should i keep both?
[Modified by GSRacer, 9:02 AM 11/14/2001]
Old Nov 14, 2001 | 08:05 AM
chri5's Avatar
its the exact same pump. If you boost with that for say the length of the 1/4 it will most likely start leaning out at the end. I would just keep both. That is how i had mine setup, and it worked fine.
Old Nov 14, 2001 | 08:12 AM
GSRacer's Avatar
New User
ok thanks, so i'm going to slap in my airtex in conjuction with my holley.
YellowPhoenix095
May 14, 2007 06:30 AM
mtber
Jul 27, 2003 10:24 PM
bottlefedb18c1
Aug 1, 2002 09:35 AM
R-1303
Jul 11, 2002 04:15 PM
sushibug
Apr 6, 2002 04:50 PM
