which injectors shuld i go with?
Old Sep 17, 2007 | 09:26 PM
lovey408's Avatar
Default which injectors shuld i go with?
im grabbin all my pieces so i can re-tune my car one last time with everything needed.. (new IC piping, maniold, turbo, boost controller, injectors.) with the new turbo i will be shootin in the 300-375HP range.. which injectors shuld i go with? i found these.. wat do u guys thnk?
http://www.streetrays.com/cata...11582
Old Sep 17, 2007 | 09:45 PM
mtber's Avatar
Default Re: which injectors shuld i go with? (lovey408)
880cc injectors would work fine.
You will need to run a resistor box with them.
Old Sep 17, 2007 | 10:37 PM
jDMJeRk's Avatar
I wouldnt go any bigger then 750cc. You dont want more injector then what you need. 880cc's would work, but I bet you would have better luck with 750cc's.
Old Sep 17, 2007 | 10:57 PM
Chris Tune's Avatar
Default Re: (jDMJeRk)
as long as he got a good tuner i dont see a bad thing from having too much injector. anyways for 375 u can do with 750's - 880's.
Old Sep 17, 2007 | 11:33 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt go any bigger then 750cc. You dont want more injector then what you need. 880cc's would work, but I bet you would have better luck with 750cc's. </TD></TR></TABLE>
The customer would notice no difference between 750cc-880cc injectors..
Its all in the tuning of the vehicle.
Old Sep 18, 2007 | 06:55 AM
FaceTuned's Avatar
Default Re: (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">
Its all in the tuning of the vehicle.</TD></TR></TABLE>
Old Sep 18, 2007 | 11:22 AM
92civicx's Avatar
310cc - 55 HP per injector -
440cc - 77 HP per injector -
525cc - 85 HP per injector -
680cc - 120 HP per injector -
780cc - 135 HP per injector -
880cc - 151 HP per injector -
1000cc - 171 HP per injector -
1600cc - 275 HP per injector -
Old Sep 18, 2007 | 11:40 AM
LastGenEK's Avatar
What Kind of engine is this going in? And Car Just curious?
Old Sep 18, 2007 | 11:45 AM
project dc2's Avatar
i'd go with some 880CC injectors, i have them in stock and since youre in the 408 you can just come pick them up. PM me with a list of all the parts you're lookin for, well work otu a deal
Old Sep 18, 2007 | 05:58 PM
lovey408's Avatar
Default Re: which injectors shuld i go with? (project dc2)
its a 00 civic si.. bottom end is built. and ill be grabbin new IC piping, manifold, turbo from u phil! just saving up lil more to grab all at once..
Old Sep 18, 2007 | 06:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lovey408 &raquo;</TD></TR><TR><TD CLASS="quote">its a 00 civic si.. bottom end is built. and ill be grabbin new IC piping, manifold, turbo from u phil! just saving up lil more to grab all at once.. </TD></TR></TABLE>
sounds good, please let me know a head of time because there are lead times on my products. thanks !
Old Sep 18, 2007 | 06:06 PM
lovey408's Avatar
how much wait time is it?
Old Sep 18, 2007 | 06:11 PM
depends on the item you're ordering. please take the questions to PM. thanks !
Old Sep 18, 2007 | 11:21 PM
lambertincorp's Avatar
880's
Old Sep 19, 2007 | 05:08 AM
Doostur's Avatar
750's will do the trick
Old Sep 19, 2007 | 05:10 AM
Schister66's Avatar
Man U FTW
I'd go w/ 880s because they're going to be small enough to control at idle, but large enough to provide plenty of fuel in your power range. Not to mention, you wont have to change them when you decide to turn up the boost and make more power
Old Sep 19, 2007 | 10:21 AM
JDogg's Avatar
Default Re: (Schister66)
dont use RC
Old Sep 19, 2007 | 11:46 AM
Schister66's Avatar
Man U FTW
Default Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">dont use RC </TD></TR></TABLE>
care to explain...??
i've been using a set of RC550cc injectors for the better part of 2 years w/ no problems
Old Sep 19, 2007 | 12:34 PM
JDogg's Avatar
i have lost 2 motors to erratic rc injectors and i have a supra in the shop with leaky/dead brand new rc1000 cc injectors
Old Sep 19, 2007 | 12:35 PM
preludestud11's Avatar
go with some 680's unless you are going to go for more power later down the road. The injectors will function better if you pic the right injector for your setup. sure you can run a 200 hp car on 1600cc injectors, but whynot jsut get the best injector for your setup? I wouldnt go any bigger than a 750, 680 would be my first choice for that power level.
Old Sep 19, 2007 | 12:45 PM
Topdawgg's Avatar
Default Re: (JDogg)
LOL
right...
tons of people use RCs and have no problems..
Ive had them for 3 years... 750s and 1000s. no problems
b18 hatch mike
Oct 5, 2010 05:59 PM
cameron4776
Sep 22, 2007 05:33 PM
spockeg
Oct 6, 2006 09:49 PM
EJ8 GSR-T
17
Dec 16, 2005 12:54 PM
stockhatch91
Nov 22, 2004 03:59 PM
