injectors saturated vs peak and hold
Old 04-25-2011, 05:30 PM
slowwcivic's Avatar
Default injectors saturated vs peak and hold
whats the difference?? which is better?
Old 04-25-2011, 06:15 PM
JDM B20 EH2's Avatar
Default Re: injectors saturated vs peak and hold
Peak and hold you have to run a resistor box with on civics and tegs. Saturated you dont they just plug in and go.
Be prepared to be told to search. Its covered alot.
Old 04-25-2011, 06:38 PM
Turbo-LS's Avatar
What are the differences between low impedance/peak & hold and high impedance/saturated injectors?
Low impedance injectors (1.5 to 4.0 Ohm) have a faster trigger times due to the type of electrical signal pattern emitted by the ECU. This “Peak and Hold” pattern uses a high (6 amp) initial current pulse to open the injector, and then a lower current signal to keep the injector open. Since the “hold” or lower current part of the signal has created a weaker magnetic field, the injector will also close quicker.
High impedance injectors (10 to 16 Ohm) are triggered by a low (1 amp) constant current signal and kept open by the same constant (saturated) current for the entire cycle. Due to the lower current needed, less heat is generated during each cycle allowing the injector to stay cool and therefore increase its reliability. The down side is that the trigger time is decreased since there is less of an initial current to actuate (open) the injector.
Most OEM injectors are saturated injectors since car manufacturers are most interested in reliability.
Old 04-26-2011, 09:42 AM
rs250nut's Avatar
^^^^ Nicely explained, thanks.
Old 04-26-2011, 11:29 AM
ashb82's Avatar
for fuel milage i like High impedance injectors. I had some Low impedance injectors 880s and they sucked for cruising and idle
Old 05-03-2011, 04:49 PM
slowwcivic's Avatar
so low impediance peak and hold is better?
Old 05-03-2011, 05:03 PM
ashb82's Avatar
no they are old technology. get some new fic or id High impedance injectors.
Old 05-04-2011, 06:22 AM
MR.johnson's Avatar
love my id2000's
KdF
Engine Management and Tuning
02-24-2009 04:36 AM
sleepersRus
01-06-2005 04:12 AM
rtpassini
11-16-2004 07:40 PM
hybrid_vtec
09-30-2004 10:07 AM
dkdjlf
09-19-2003 02:31 AM
Quick Reply: injectors saturated vs peak and hold
