injectors for race gas
Old 07-14-2012, 09:16 AM
prj
prj's Avatar
Default injectors for race gas
the last thing i need for the upgrade on my car is injectors. right now i have a set of precision 1000s and looking for something more reliable and that can handle the extra fuel. what injectors are you guys running with race gas? my goal is to be around 600-650hp on my sc61.
Old 07-15-2012, 08:20 AM
prj
prj's Avatar
Default Re: injectors for race gas
any help?
Old 07-15-2012, 12:24 PM
HiProfile's Avatar
That looks like King's dyno in the picture. Any 900-1000cc Bosch Ev14 injector will be enough, barely, but will work fine (ID1000, FIC 900, Five-O 900 - all the same). A few have started selling some 1100cc EV14's. I know someone who's tuned them before, and work great. Other types have a very poor spray pattern, or don't react well to higher fuel pressures. The 1600cc and 2200cc Bosch (ID2200, etc) have seals/seats that swell with fuel temp AND some chemicals in most race gas.
I've heard some tuners say they've had more than a few sets from a certain brand be as much as 10% off (unmatched from each other). I've also seen people have their sets be tested and be far off from the initial flow sheet and poorly matched (well over 1% difference).
Send me a PM if you want more detailed info.
Old 07-15-2012, 12:40 PM
prj
prj's Avatar
yeah, king has done most of the work on the car from what i understand. the pic was from the last king dyno day.
Old 07-15-2012, 08:28 PM
prj
prj's Avatar
anyone ever use the deutchwerks 1300s or the fic 1100s?
Old 07-15-2012, 08:36 PM
Who is Mr Robot?
wantboost's Avatar
Do you need more injector? No reason to go way bigger if you aren't making the power... A lot of times larger injectors don't like lower pulsewidths so they idle like **** and run weird at low load/rpm
but if you ditch the 1000s... I want em :p
Old 07-15-2012, 08:47 PM
prj
prj's Avatar
well i should be in the 600hp range when i switch over to vp112 fuel, but it sounds like the id1000s and fic1100 hi-z's should be fine for that.
i will be getting rid of the precision 1000s though.
Old 07-16-2012, 04:26 AM
fcluddington's Avatar
I would think with a good fuel pump setup the id1000 would work. How much can your pump increase the fuel psi?
Old 07-16-2012, 09:46 AM
prj
prj's Avatar
not sure. right now in the take is a walbro 255hp, but i just bought a walbro 400hp to put in.
Old 07-16-2012, 11:16 AM
turbocrx440whp's Avatar
ive got id1000's and a 255 made 560@24lbs on vpms 109
king tuned
Old 07-16-2012, 11:24 AM
Who is Mr Robot?
wantboost's Avatar
assuming a base pressure of 42 psi you were using roughly 215lph of fuel at that power level... thats basically where things start to decrease as pressure goes up... thats pretty much the reasonable limit of the pump
Old 07-16-2012, 05:27 PM
HiProfile's Avatar
600whp would be maxing out 900cc's at 3bar of fuel pressure, assuming pump gas. Race gas makes a bit more power per "squirt" than pump gas. 900's with a bit more pressure and race gas should get to 650whp, if you use the larger pump. The nice thing about the Bosch injectors is you can crank the fuel pressure.
The FIC 1150's are just as responsive as the ID1000's people have seen lots of, but flow 25% more fuel when tested the same way. ID1000's actually flow ~880-900cc when tested with Heptane-N.
Old 07-16-2012, 07:37 PM
Who is Mr Robot?
wantboost's Avatar
by my calculations 548 is the limit for pump gas on 900cc injectors.
1000s would get to 604
1150s would be 701
this is assuming 80% max duty cycle and a BSFC of .50
delfast
02-26-2010 03:21 PM
integrawow
06-15-2009 07:43 PM
avividmemory
11-05-2002 03:11 PM
LudemanDan
10-02-2002 10:24 PM
Sh4rky
02-25-2002 11:38 AM
Quick Reply: injectors for race gas
