power potential
Old Feb 25, 2010 | 06:25 PM
delfast's Avatar
Default power potential
Hey everyone i am wondering what hp i can be excpecting with my next setup, and some advice on what fuel i should run. Right now i currently have a built b18c1 with 10.1 base compression, with a precision sc61 running 25lbs, i have a single walboro with 1000cc injectors tuned on e85 making 500hp, my injectors are at 95% duty cycle right now, and I am running stock base fuel pres. I plan on runing dual in tank walboro's and either switching the fuel or having to get bigger injectors. So my question is what hp would i be looking at by switching to race gas and which race gas should i use? or is it better to stay with e85 and get bigger injectors?
Thanks in advance
Matt
Old Feb 26, 2010 | 05:35 AM
delfast's Avatar
Default Re: power potential
anyone?
Old Feb 26, 2010 | 05:47 AM
tuhboek's Avatar
go with some ID1000cc injectors + Bosch 044 inline pump with some Q16....I believe you would be good for 650hp-700hp range...
Old Feb 26, 2010 | 05:49 AM
92redhatch's Avatar
Your making 500whp on a single walbro w/ 1000's? That's pushing the limit of your walbro. If you want to be able to make more power I would sump the tank and get a two 044's. And then make 700+. But to answer your question with two walbros And e85 i think youll be madre out about 600whp.
Old Feb 26, 2010 | 07:02 AM
96 GSR-T's Avatar
700+ out of an SC61?
Anyway.... It really dont matter how many Walbro's you run those 1000's are just about maxed out on E85, people have made 600+/- on a set of ID1000's and a 255 intank to an inline 044 and E85 with high base pressure, I am pretty sure that combo is good for 750hp on Gas. You should be able to just about max out your SC61 with your current fuel system if you just switch to Gas.
Old Feb 26, 2010 | 07:50 AM
92redhatch's Avatar
Not on an sc61. I'm just saying what the fuel system would be capable of.
Old Feb 26, 2010 | 09:09 AM
2.0 and up's Avatar
a single walbro can make way over 500... ive seen seen a setup make 650whp on a single walbro
Old Feb 26, 2010 | 09:49 AM
92redhatch's Avatar
Yeah but not on e85!
Old Feb 26, 2010 | 03:21 PM
delfast's Avatar
thanks for all the help guys! so from what you all are saying if i switch to gas and run either another walboro or a 044 i will max out my turbo at around 600-650ish? what is the max power someone has seen from a 61?
supersilverdc2
Feb 14, 2015 07:33 PM
SPOOLINmatt
Dec 6, 2009 04:03 PM
Marc_Smith
Sep 23, 2009 07:41 AM
b16b18
Sep 3, 2008 07:38 AM
Sh4rky
Feb 25, 2002 11:38 AM
