Injector Wiring Colors...What Are They and What Order??
Here is the story: I had to change my head gasket. I did so and in the mean time i went ahead and bought a new Intake manifold. Well I had to cut and splice my injector wires to extend them for my new intake manifold. They are all practically the same size now. I think i might have mixed up the wires for the injectors for cyl 3 and 4. Now I searched and found this:
Injector #1 (closest to driver's side)
solid brown wire
yellow wire w/ black stripe
Injector #2
solid red wire
Injector #3
solid blue wire
Injector #4
solid yellow wire
Is this correct?? I am pretty sure i mixed up these wires because I started the car after all was said and done the car had a flashing CEL, which after searching means a bad misfire. Now will mixing up the injector wires cause a flashing CEL, misfire??? Also could starting it with this misfire damage anything?? TIA!
solid brown wire
Injector #2
solid red wire
Injector #3
solid blue wire
Injector #4
solid yellow wire
yes that is the correct order 1-BROWN 2-RED 3-BLUE 4-YELLOW. as for your flashing CEL that means your having severe misfires that will damage your cat. when you wired your injectors back together did you solder them or did you just twist them and wrap them with electrical tape?
well i have hondata s300 and there is a code for the water temp sensor because the wires came disconnected right where it goes into the clip. so i will be fixing that tomorrow. but besides that the car idles at 1500 and the check engine flashes every 5 seconds. just a very quick flash. i havent driven the car yet, it has only been started for about 30 seconds at a time and idling.
edit: also my aem a/f guages is reading very lean, so i have a feeling it may have something to do with injectors...
95dc2teg
12-16-2008 02:53 PM
Tippyman
14
03-27-2006 08:55 PM
Mr. Vapor
04-27-2005 12:29 PM
