injector size
Old Oct 19, 2003 | 06:07 PM
JR-GSR's Avatar
Default injector size
i have a stock usdm gsr motor and i want to run about 8psi. can i do this with stock injector and a fmu and then use a vafc to tune it, or would it be better to get bigger injectors and just use the vafc.
Old Oct 19, 2003 | 06:08 PM
bigwig's Avatar
Default Re: injector size (JR-GSR)
310cc-450cc would be a better choice.
rjardy's Avatar
you can do either, or you can get a better free management like uberdata. Anyone with a little common sense can use this program.
Rob
Old Oct 19, 2003 | 06:10 PM
JR-GSR's Avatar
so get 310's and not use the fmu, would i have any problem idle or any thing?
Old Oct 20, 2003 | 11:04 AM
tnosloco's Avatar
i think you would have a little of idle problem.
Old Oct 20, 2003 | 11:44 AM
falcongsr's Avatar
What is this crap?
Default Re: injector size (tnosloco)
just FYI i run 310s on my greddy kit and i maxed those injectors out! 100% duty cycle and leaning out at 6800rpm.
Old Oct 20, 2003 | 11:58 AM
falcongsr's Avatar
What is this crap?
Default Re: injector size (rjardy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">you can do either, or you can get a better free management like uberdata. Anyone with a little common sense can use this program.
Rob</TD></TR></TABLE>
hey man, i consider myself a pretty intelligent individual and i'll say that using something like uberdata isn't a piece of cake. every setup is going to have some unique quirks that will make it a challenge to get running right. its nowhere near the level of refinement or support available with hondata. unless your setup is identical to someone elses you'll probly have to end up editing the code manually to get what you want. maybe the next versions of the free romeditors out there will be better...we will see...
juniestyle
Apr 18, 2006 09:13 AM
tspkenneth
Feb 20, 2005 07:15 AM
xxthabest1xx
Apr 1, 2004 08:06 AM
othick
Jun 12, 2003 10:41 PM
speed
Nov 14, 2002 08:38 AM
