INJECTOR GROUPBUY
Old Oct 30, 2001 | 08:16 PM
B17aTrbo's Avatar
New User
Default INJECTOR GROUPBUY
i was checking out GROUPBUY.COM and i saw that there is an injector buy...this is the one i have been waiting for! i just need to know which size i should go with...i have the drag gen 2 turbo kit with what the kit came with for fuel (in-tank pump, 12:1 FMU, VAFC)...i don't wanna go to a standalone right now...they have 310s, 440s, and 550s...i had 550s for my eclipse but is that too big for a honda? thanks...later.
Corey
Old Oct 31, 2001 | 06:29 AM
VTC_CiViC's Avatar
Default Re: INJECTOR GROUPBUY (B17aTURBO)
If you're not going standalone yet, then the biggest you can use would be a 440, and you'll need an AFC to trim it at idle and partial throttle or you'll barley be able to idle, if you can idle at all. Largest the stock ECU itself can handle I belive is 310cc.. so depending on how you're dealing with your fuel you'll have to decide. I say go with the 440's now + an AFC. When you do go standalone, the 440's can remain since their pretty big injectors and can supply fuel up to something like 15psi or over 300whp. May as well just but them once.
Old Oct 31, 2001 | 06:46 AM
newsense's Avatar
New User
Default Re: INJECTOR GROUPBUY (VTC_CiViC)
well put .... thats what i did.... havent been able to put them in yet tho so i cant say for sure if it will idle right
turbod16y7vtec
Nov 2, 2002 07:43 AM
deacs
Sep 20, 2002 12:26 PM
Turbo_Si
Jul 26, 2002 04:19 PM
uneekcrx
May 9, 2002 04:59 AM
SpeedMonkeyRacing
Oct 4, 2001 07:28 AM
