How does CR affect hp?
Old Oct 30, 2001 | 07:02 AM
98Psi ITR's Avatar
Default How does CR affect hp?
Is there a formula? I have 9.0:1 pistons in a 1.8L and Type R head. When calculating the hp for a specific turbo how does the cr come into play?
Old Oct 30, 2001 | 07:05 AM
TurboT's Avatar
Default Re: How does CR affect hp? (98Psi ITR)
CR will come into the calculation for dynamic compression which factors in boost...
so basically, you need more boost to match the dynamic compression of someone with 10:1 compression....
on the side, 9:1 pistons and a ITR head... if those are GSR 9:1 pistons, then you'll get about 8.8:1
Old Oct 30, 2001 | 07:42 AM
98Psi ITR's Avatar
so besides the dyno, how do you make these calculations?
Old Oct 31, 2001 | 07:34 AM
TurboT's Avatar
i forgot where, but a website i came across calculated dynamic compression for you...
it was a javascript program i believe...
anyone know?
yellowmonkeyboy
Oct 1, 2004 03:38 PM
The ZC
Aug 28, 2004 06:29 PM
JDM 007
Jan 24, 2003 01:08 PM
jap-spec
Jan 16, 2003 09:35 PM
