i'm confused now...
Old Jun 12, 2003 | 05:40 PM
NuclearB18B's Avatar
Default i'm confused now...
ok, i've been reading up on turbos, manifolds, 4-bolt vs 5-bolt, etc. and it's lead me to this conclusioin...i'm really f*cking confused. so i'm going to ask my question and hope that someone can answer it for me so i can stop being confused...here goes...
i've got a 96 LS with a fluidyne radiator and the stock fans. i'm planning on running the t3/to4e 57 trim w/ .63 a/r housing. now my question is...what manifold can i run with this without having to shave anything and still be able to keep my a/c? also, is there going to be enough clearance with the stock fans on the fluidyne? if not, what can i do to make room? thanks in advance for the help
Old Jun 12, 2003 | 05:53 PM
93LSivic's Avatar
Default Re: i'm confused now... (ha illuminato un)
4 bolt turbine is a better housing. Its more tangenial and has better flow characteristics then the 5 bolt. Arturbo had a really nice post on this months back, try searching the archives under his name.
Most guys will do a pusher style radiator fan...where it mounts to the front of the radiator.
Most manifolds will require you to shave the webbing on the block, but I think the Inline Pro with a 4 bolt turbo combination you dont have to....i think thats what it was.
Old Jun 12, 2003 | 07:10 PM
intekragsr's Avatar
Default Re: i'm confused now... (93LSivic)
you wont fit ANYTHING with a fluidyne and stock fans. Get some slim ones.
I have the same turbo and a drag manifold. Just shave the block. Its not hard.
Old Jun 12, 2003 | 07:15 PM
DIRep972's Avatar
Smarter than you
actually its the inline pro/ 5 bolt combination that requires the least about of shaving. 4bolt still requires alot of shaving.
shaving the block webbing isn't a big deal though, its when u have to shave it next to the serial # and flywheel that makes me cringe.
In order to run a fluidyne radiator w/ inline pro mani and AC you are going to have to either buy a slim fan or run the stock fans as pushers on the backside.
good luck Aaron.
Old Jun 12, 2003 | 07:33 PM
Default Re: i'm confused now... (DIRep)
thanks chris
Old Jun 12, 2003 | 10:44 PM
InTeGrA B18b1's Avatar
i got the same turbo and one day i just test fitted the turbo and all i had to do is trim the fans and fan case. It just enough room
g2turbo
Mar 10, 2009 03:37 PM
SIRIUS VTEC
Welding / Fabrication
Jun 5, 2008 07:15 AM
96 Ls lnTeG
Jan 2, 2004 10:11 AM
00ITR #543
Jan 30, 2003 05:13 AM
Cyber ITR
Nov 6, 2002 09:29 AM
