60-1 fitment question
Old Nov 5, 2002 | 02:41 AM
Cyber ITR's Avatar
Default 60-1 fitment question
hey guys
im thinking to get t3/60-1 turbo for my car, EF CRX ( B18C )
i just wondering if there will be enough space in the engine bay ?
do i need to get smaller size radiator ?
Old Nov 5, 2002 | 02:46 AM
MiraiZ's Avatar
Default Re: 60-1 fitment question (VTEC_SiR)
JDM_DOHC_SIR has a CR-X hybrid....his engine compartment is so tight dude...I don't thing toy could get anything larger than a t3 in there...t3/t4 would hit the fans and radiator core...I guess if you got a low profile single fan, it might squeeze in...
Old Nov 5, 2002 | 05:04 AM
boostaholic's Avatar
Default Re: 60-1 fitment question (MiraiZ)
You will probably have to run the civic half size radiator and a slim line fan.
Old Nov 5, 2002 | 07:11 AM
true's Avatar
Default Re: 60-1 fitment question (boostaholic)
Definetly need at least an EG radiator...If you want a good flowing 3" dp, you'll probably need a custom radiator too. I did.
Old Nov 5, 2002 | 08:03 AM
JDM88EF9's Avatar
Default Re: 60-1 fitment question (true)
Or you can go ahead and use the 95-99 Neon Radiator.
Old Nov 5, 2002 | 10:40 AM
boosted hybrid's Avatar
Try running the half size radiator and then use a pusher fan, one that is mounted in front of the radiator. You will have the room you need then.
Old Nov 5, 2002 | 02:06 PM
Cyber ITR's Avatar
Default Re: 60-1 fitment question (boosted hybrid)
how much for the push fan thingy and custom radiator core say as big as EG's radiator ?
thanks
Old Nov 5, 2002 | 07:17 PM
You can use a del sol vtec dual core radiator. Its the same dimensions as the stock cx/dx radiators but is double as thick and has much more cooling potential. The pusher fans are available at any autoparts store. Just buy an aftermarket fan preferablly in 10" or 12", 12" being the largest you will be able to fit in front of the radiator. You can run the motor on most of the aftermarket radiator fans in either direction, so just give the motor power and see what polarity you need to run to make it push the air. Its quite simply, and the fan assembly should include directions explaining all of what i am saying. Autozone has ones that flow more than the FAL fans, for 45.00.
Old Nov 5, 2002 | 09:01 PM
SiR Kid's Avatar
New User
I've got a 4/3 hybrid on an FMAX manifold with my B16a on Hasport Mounts.
I've got about half an inch clearance, but i'll be removing that with my step up to a SLIGHTLY larger 4/3 hybrid...
I wanted to go 60-1, but I've put it out of my head as impossible without changing ALOT of stuff, which I don't have the cheese for.
[edit] OH YEAH, FYI, that's a 1-800-RADIATOR brass core stock size radiator.[/edit]
here's a shot of radiator/wastegate spacing, which is about how much room there is from the compressor housing as well...
[Modified by SiR Kid, 12:03 AM 11/6/2002]
Old Nov 5, 2002 | 09:17 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: 60-1 fitment question (SiR Kid)
Is that air-liquid intercooler running well still? I've pmmed u before about it but i'm just curious. I don't see too many air-liquid intercoolers out there except on drag cars.
Old Nov 5, 2002 | 09:27 PM
SiR Kid's Avatar
New User
Default Re: 60-1 fitment question (PreIudeSI)
Mine runs great... I've developed a SMALL leak at the corner of my aluminum reservoir, it only drips 5-6 times over night, so it's not a pressing issue, but the car is doing great.
BTW, we were AMAZED at the dyno. After 30 dyno pulls in under 2 hours, the intercooler water never got above luke warm temps, I can't say anywhere near as much for my radiator/engine temps...they rose pretty badly during pulls. :/
Old Nov 6, 2002 | 09:09 AM
SiRkid's Avatar
i dunno if its worth the hastle to go with an air -water(imo)
Old Nov 6, 2002 | 09:29 AM
dvp95's Avatar
Default Re: 60-1 fitment question (SiRkid)
I dont want to sound stupid or anything, but is a t3/60-1 bigger than a t4? Im looking for a turbo for my accord h22a, but im not sure on the size, specs, or good brands. Thanks
prahaian
Jan 5, 2014 01:02 PM
DEIVIONCRX
Jul 30, 2009 05:12 AM
dAng! Kris
Apr 6, 2005 07:40 PM
blkrice
Jan 17, 2003 10:13 PM
