Ignition for turbo application
Old Jul 26, 2005 | 06:02 PM
shoebox's Avatar
Default Ignition for turbo application
I have a turbo d series in a EG hatch. Right now I am running the stock ignition with some NGK7rE11 plugs. My question is if I should be running some sort of aftermarket igntion and "high" output coil, and what are some of the ignitions that you would recommend. Not just MSD, but exactly what you would recommend. Also what is a good brand of plug wires. People have told me that the NGK plug wires tend to pop off and fry out ignitors. If anybody could help that would be great!!!!!
Old Jul 26, 2005 | 08:09 PM
Tchleung's Avatar
stock Ignition setup. NGK or OEM wires. Whoever said NGK pop off and fry ignitors is wrong.
Old Jul 27, 2005 | 02:58 PM
shoebox's Avatar
Default Re: (Tchleung)
just keep everythign stock? I shouldn't even buy a new coil or anything?
Old Jul 27, 2005 | 04:45 PM
Tchleung's Avatar
Why if it works. the OE ignition setup is good for huge power. There are many ametuer and pro guys running 500+hp on stock IGN. If anythnig I'd just replace the cap and rotor with a new one
Old Jul 27, 2005 | 04:52 PM
Flr Power's Avatar
I second that. Don't fall into the BS...
Old Jul 27, 2005 | 06:06 PM
mrlegoman's Avatar
Default Re: (Flr Power)
I've questioned the ignition system before too and have been told the same exact thing, stick with stock.
Besides, look closely into the 'aftermarket' ignition coils, none of them are rated for more then 6K. Kinda worthless for a engine reving to 9.
Old Jul 27, 2005 | 06:31 PM
631 Teggy's Avatar
Default Re: (mrlegoman)
Ignition is nice for the rev limiter. It's better to have an spark cut-off instead of the stock FUEL cut off...
Old Jul 27, 2005 | 06:40 PM
shoebox's Avatar
Default Re: (631 Teggy)
Sweet, then that is just one less thing that I have to worry about buying!
Old Jul 27, 2005 | 06:46 PM
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrlegoman &raquo;</TD></TR><TR><TD CLASS="quote">
Besides, look closely into the 'aftermarket' ignition coils, none of them are rated for more then 6K. Kinda worthless for a engine reving to 9.</TD></TR></TABLE>
Where have you read this?
Old Jul 27, 2005 | 07:49 PM
YiNYaNg's Avatar
Default Re: Ignition for turbo application (shoebox)
Stock ignition is good enough...
Spend your money on other parts like a good EMS... S300 or Neptune...etc...
Old Jul 27, 2005 | 08:02 PM
mrlegoman's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Where have you read this?</TD></TR></TABLE>This was in the fine print for mostMSD and Accel coils that I looked at.
Old Jul 28, 2005 | 08:46 AM
MrBui's Avatar
all im running is an external msd coil and cap o yea ngk wires... worked all the way til 30psi and almost 600hp
Old Jul 28, 2005 | 09:34 AM
lucidvtec's Avatar
i got the msd mod cap...ngk wires....is it ok to use the blaster 2 coil....or do i need to get the ss blaster coil????....
Old Jul 28, 2005 | 09:43 AM
Squirtle's Avatar
600 with just a coil and cap awesome.
Old Jul 28, 2005 | 09:54 AM
FOrSfEd's Avatar
Default Re: (squirtle)
Stock all the way
YashiMotors
Mar 12, 2005 12:46 PM
DarkDragon
Jan 30, 2005 08:33 AM
BETO736
Jun 4, 2004 11:04 AM
92HB_HB
Apr 7, 2004 03:50 PM
smoothludey2
Jan 7, 2002 08:00 PM
