If I Mount A Turbo Upside Down, What's The Worst That Could Happen?
Old 05-26-2004, 04:14 AM
ijcameron's Avatar
Default If I Mount A Turbo Upside Down, What's The Worst That Could Happen?
I've got a junkyard Mitsubishi TE04H, there's no way to swap the compressor and exhaust sides. I'm having a real problem getting it where I want it on my A1 - my solution was to mount it "upside down", that is with the oil supply becoming the oil drain, and vice versa .
The center cartridge just needs oil, right? Does anyone see any problems with this?
Old 05-26-2004, 04:31 AM
oscarmayer's Avatar
Default Re: If I Mount A Turbo Upside Down, What's The Worst That Could Happen? (ijcameron)
you burn up the turbo. the oil has to be able to drain out of the bottom back into the pan. or else you will ruin the turbo by cooking the bearings.
Old 05-26-2004, 05:39 AM
JonGP4's Avatar
Default Re: If I Mount A Turbo Upside Down, What's The Worst That Could Happen? (oscarmayer)
will NOT work, the feed side goes directly in the bearing journals, and the drain side is low pressure oil coming out of the bearing.. you can not reverse it.. its there for a reason
Old 05-26-2004, 06:52 AM
SleepyEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ijcameron &raquo;</TD></TR><TR><TD CLASS="quote">I've got a junkyard Mitsubishi TE04H, there's no way to swap the compressor and exhaust sides. I'm having a real problem getting it where I want it on my A1 - my solution was to mount it "upside down", that is with the oil supply becoming the oil drain, and vice versa .
why not clock both sides 180° ?
Old 05-26-2004, 07:10 AM
DaX
DaX's Avatar
Default Re: If I Mount A Turbo Upside Down, What's The Worst That Could Happen? (SleepyEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepyEG &raquo;</TD></TR><TR><TD CLASS="quote">
why not clock both sides 180° ?</TD></TR></TABLE>
Old 05-26-2004, 07:11 AM
B18C1CYA's Avatar
Default Re: If I Mount A Turbo Upside Down, What's The Worst That Could Happen? (DaX)
just clock it, if its clockable
Old 05-26-2004, 07:17 AM
SleepyEG's Avatar
Default Re: If I Mount A Turbo Upside Down, What's The Worst That Could Happen? (B18C1CYA)
I'm assuming he meant to say TD04H, not TE04H...if so, I have clocked a compressor housing personally, you just have to carefully file yourself a new groove for the pin..On the exhaust side, you'll need to drill a little tiny hole for the housings pin, or you could break it off, but that seems like a horrible idea.
EJ1 wilcox's Avatar
I thought all turbos were clockable?
Some are just more of a pain than others.
My compressor has a huge snap ring instead of bolts... I can't find big enough snap ring pliers to rotate it I'll just keep looking.
Old 05-26-2004, 07:23 AM
SleepyEG's Avatar
Default Re: If I Mount A Turbo Upside Down, What's The Worst That Could Happen? (koreanwilcox)
The snap ring is holding the housing on, but that's not what is keeping it from rotating. It's not worth trying to explain, if you take it apart it's obvious, there's a little pin thing.
Old 05-26-2004, 08:33 AM
CRX T-Si's Avatar
If you can't clock it then you can't use it, bottom line.
Use some PB blaster on it to loosen the rust a bit and see if you can tap that sucker with a hammer. It just needs a little encouragement.
Old 05-26-2004, 08:40 AM
Stu
New User
Stu's Avatar
Aren't turbos with internal wastegates very limited with how much you can clock them? And, why do you need to swap the compressor and turbine sides?
Old 05-26-2004, 09:03 AM
EJ1 wilcox's Avatar
Default Re: (Stu)
If you have an internal wastegate you just have to drill and tap the compressor housing for the new wastegate position.
Just clock the turbo how you need it, then mark the holes and mount the wastegate actuator.
Old 05-26-2004, 09:24 AM
SleepyEG's Avatar
Default Re: (koreanwilcox)
I just used the original mounting holes and built a little bracket, easier than having to tap the housing IMHO. Either way, it's not a hard thing to do!
Old 05-26-2004, 09:50 AM
EJ1 wilcox's Avatar
Default Re: (SleepyEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepyEG &raquo;</TD></TR><TR><TD CLASS="quote">I just used the original mounting holes and built a little bracket, easier than having to tap the housing IMHO. Either way, it's not a hard thing to do!</TD></TR></TABLE>
Really? How did you do this? I would rather build a bracket but I didn't think there was a way??
Do you have any pics or a description of how you did it? Materials used etc??
Sorry this is OT but I'm interested!
Old 05-28-2004, 08:46 AM
SleepyEG's Avatar
I just clocked the compressor housing so that the outlet was pointing down. At that point my mounting holes were like 180° off.. I just made a bracket to relocate the holes..nothing special. I can try to get a picture but I'm not sure how easy it will be to see on the car.
It's clocking the housing I'd worry about. You have to file a groove into the center section, flush with the gasket, without tearing the gasket, but without getting metal anywhere, I put a piece of tape over the gasket and ground down to it..HTH
Old 05-28-2004, 10:25 AM
CRX T-Si's Avatar
Why would you need to file a groove in the center housing????
Your right about the gasket part, be extremely careful not to tear the carbon seal.
and how are you doing this with the turbo in the car already?? don't try to take the short cut man cause it will come back and hurt ca.
Old 05-28-2004, 10:56 AM
Jeffescortlx's Avatar
Default Re: (CRX T-Si)
Some of the DSM turbo's have a little "tab" that stop's you from clocking it.
Old 05-28-2004, 11:03 AM
DaX
DaX's Avatar
Default Re: (Jeffescortlx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeffescortlx &raquo;</TD></TR><TR><TD CLASS="quote">Some of the DSM turbo's have a little "tab" that stop's you from clocking it.</TD></TR></TABLE>
This is what he was refering to filing down.
Old 05-28-2004, 12:25 PM
SleepyEG's Avatar
Default Re: (DaX)
Thanks Dax, I'm glad someone is following. I'm not taking any shortcuts, I was referring to the tab "that stops you from clocking" It doesn't stop you, you just need to make a new hole for it, which is what I was talking about. If you don't have a mitsu turbo, don't worry about it.
What I was talking about doing was taking a picture, not filing anything down.
NEAL FRISBIE
03-01-2011 09:42 AM
boostedb20z
11-14-2009 10:12 PM
TylerB
09-17-2009 09:54 PM
E-Rok
04-10-2003 02:10 PM
filetofit
09-05-2002 09:26 PM
Quick Reply: If I Mount A Turbo Upside Down, What's The Worst That Could Happen?
