Idling issue with the hack.
Old Aug 4, 2003 | 04:47 PM
spike's Avatar
Default Idling issue with the hack.
Just got done working on a CRX with a t3/t4 setup running the hack. Car hasn't idled for more than 1 minute before we figured out there was a slight oil leak. The entire time it was idling however it was at like 2500 rpms or so.. idled fine before the turbo install. Has anyone else run into this? Car has only been sitting for around 3 weeks.. not too long and it is definitely not cold out.. I guess we'll just mess with the idle screw.. but anyone else run into this? Thanks!
Spike
Old Aug 4, 2003 | 04:50 PM
Accord94DX's Avatar
Default Re: Idling issue with the hack. (spike)
what pressure sensor settings are you running?
Old Aug 4, 2003 | 04:52 PM
spike's Avatar
Default Re: Idling issue with the hack. (Accord94DX)
on the afc? i think it's in and out 6.. it's on a b16a1 btw.
Old Aug 4, 2003 | 05:30 PM
Alstare's Avatar
I set my 1k setting stupidly rich and it idles mint... like -20 for the 1000rpm..
Seems to work well...
Old Aug 4, 2003 | 05:47 PM
_jester_'s Avatar
Default Re: Idling issue with the hack. (Alstare)
i have my hack tuned to -50 @ idle. Idles like stock, almost perfect 750~ rpm's. However i have a skunk2 ecu. Wouldn't -20 be extremely lean?
Old Aug 4, 2003 | 06:02 PM
SOFLSOL's Avatar
Default Re: Idling issue with the hack. (XratedSi)
the lower the settings the richer. for example -20 is richer than -40
Old Aug 4, 2003 | 06:04 PM
Joseph Davis's Avatar
Most ppl bog the idle with fuel to keep it from surging. An idle of 2500 rpms, well, the FITV needs a minute or two to warm up before you go chasing a problem... feel free to suspect one though. IMO you need more time with the car running.
Did you get ECU Control working??
XratedSi... ditch that skank2 chip asap. Not only is the ignition way advanced since it is for a NA car, but skank2 does a lovely job of disabling the majority of the ECU self-check routines... if you have a problem with a sensor or ground or such taking a crap, the ECU kicks no codes.
Old Aug 4, 2003 | 06:08 PM
M-EJ1's Avatar
Default Re: Idling issue with the hack. (J. Davis)
What setting are you running for the 1k RPM fuel range? I had to set my shitty rich to make the car idle, and I get an occasional backfire when taking off from a stoplight or something where it's been idling, but other than that it idles great.
Old Aug 4, 2003 | 06:14 PM
spike's Avatar
Default Re: Idling issue with the hack. (M-EJ1)
I haven't had a chance to mess with the ECUControl yet J. Davis.. unfortunately we've been trying to turbo this kids b16a crx and ran into nothing but problems.. i keep cursing out that damn Crossmember.. makes everything a bitch.. anyway.. i'll try making it pig rich at an idle and see if that helps.. once we get this oil return leak fixed we'll let it warm up for real..
thanks guys!
Old Aug 6, 2003 | 07:36 PM
Bailhatch's Avatar
I have mine at -15 at 800rpm with dsm 440s. It idles a little rougher than stock but always picks right up, no hesitation on tip in. The motor sounds horrible if I try to lean it out. I haven't really tried any other settings in the last week I have had the hack and turbo running. It seems fine and the O2 reads between .05 and .6volts at idle so kinda lean i guess. I have read that big injectors have a slower response time at low duty cycle so they need a richer signal but produce a good A/F for idle. Everyone on HT says that too rich of a setting, i'm not convinced yet.
Old Aug 6, 2003 | 07:38 PM
Accord94DX's Avatar
-32 at idle, its like stock.
Old Aug 6, 2003 | 08:13 PM
spike's Avatar
finally got it good.. -50 for 1k and 2k both.. the problem actually was the the throttle nut was a little too tight and only when the car was on did it register ~4% throttle.. kinda wierd.. guess they did that when they did the swap.. anyone idles like a champ now! thanks guys
Old Aug 6, 2003 | 08:20 PM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spike &raquo;</TD></TR><TR><TD CLASS="quote">finally got it good.. -50 for 1k and 2k both.. the problem actually was the the throttle nut was a little too tight and only when the car was on did it register ~4% throttle.. kinda wierd.. guess they did that when they did the swap.. anyone idles like a champ now! thanks guys</TD></TR></TABLE>
The hack is weird. My car liked -40% for idle. Any difference and it was crap. Some cars like -50% some cars like -20% at idle.
Strange!
liam
Old Aug 6, 2003 | 08:32 PM
DIY_Racing's Avatar
J. Davis, you need to contact me at http://runnin46@Hotmail.com as soon as possible ok.... please.
Old Aug 7, 2003 | 12:05 AM
Mase's Avatar
Default Re: Idling issue with the hack. (DIY_Racing)
on a sohc civic ex motor, dsm 450's afc hack, at -50 at idle, the afr via my wideband read 14.7.
most of you guys are probably running pretty damn rich at idle
Old Aug 7, 2003 | 02:50 AM
liam821's Avatar
25 Year Member
Default Re: Idling issue with the hack. (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">on a sohc civic ex motor, dsm 450's afc hack, at -50 at idle, the afr via my wideband read 14.7.
most of you guys are probably running pretty damn rich at idle</TD></TR></TABLE>
see mine wouldnt run at all at -50%. It was just plain unhappy.
liam
Old Aug 7, 2003 | 06:50 AM
Bailhatch's Avatar
Default Re: Idling issue with the hack. (liam821)
does A/F at idle really matter? After reading this post I got mine leaned out a little, it's at -22 now. seems a little smoother. -35 sounds like its gonna give up on me...at idle my O2 voltage is about .6 wich should be pretty good, right? Would it be better to reset the ECU after making a change like this to make the long term map better or will the ECU fix its self?
Old Aug 7, 2003 | 04:02 PM
psileepR's Avatar
New User
Default Re: Idling issue with the hack. (Bailhatch)
a lil OT but it still regards the hack.
setting the hi/lo on the afc .... is it better to have it at 49%/50% or 98%/99% or does it not even matter?
Discosteak
Sep 9, 2005 08:13 AM
ExVtec
May 16, 2004 07:48 PM
eg2_RE
Nov 22, 2003 11:15 PM
omahaturbocivic
Mar 6, 2003 10:02 PM
khcivic
Feb 11, 2003 06:37 PM
