Idle Problem during cold start. Please help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">Sohc Driver and TurboBumblBee.. do you have evap line unplugged or connector unplugged? because thats another problem with hondata at least on obd2 cars. i had low idle issue due to that, if you look inside engine bay, theres an evap line from fuel tank, you can unplug the connector right above IM, i've done that at first and idle is much sharper at all times. for some reason it opens right during startup and causing running rich, but my current issue is not from that, i also disconnected and plugged evap hose.</TD></TR></TABLE>
bump... im actually out of town now for the holidays but i will give this a shot when i get home.. i know that the evap purge is wired in the car right now..
so basically your saying try taking out the charcoal canister that is on the firewall and plug up which lines??
whats the afr's at when you start your car when its cold?im running the aem ecu and we get pretty cold over here,as low as -50 brrrr.my car had the same problem.richen it up a little in the iat table or cold start tables if hondata has this option
.when you start your car it likes to be pig rich (like 10.5) until it hits the desired coolant temp.and how much timing you running during inital cranking?
Modified by 0vrbst at 1:51 PM 12/25/2004
.when you start your car it likes to be pig rich (like 10.5) until it hits the desired coolant temp.and how much timing you running during inital cranking?Modified by 0vrbst at 1:51 PM 12/25/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0vrbst »</TD></TR><TR><TD CLASS="quote">whats the afr's at when you start your car when its cold?im running the aem ecu and we get pretty cold over here,as low as -50 brrrr.my car had the same problem.richen it up a little in the iat table or cold start tables if hondata has this option
Modified by 0vrbst at 1:51 PM 12/25/2004</TD></TR></TABLE>
i wish i knew, although my car was tuned during this type of weather, it ran just fine a year ago.. i have no idea regarding timing.. i'll give a try to cleaning air control valve.. hope it helps
.when you start your car it likes to be pig rich (like 10.5) until it hits the desired coolant temp.and how much timing you running during inital cranking?Modified by 0vrbst at 1:51 PM 12/25/2004</TD></TR></TABLE>
raverx3m
Engine Management and Tuning
153
Jul 12, 2017 12:06 PM
honkyb18c
Aug 20, 2009 09:10 AM
