What size wastegate for my SC61?
Just wondering what you guys all think...
I have a Precisoin Sc61, and I will be running 15-17lbs on 93 octane and POSSIBLY 20-23lbs on 110 octane fuel.
I want to eliminate boost creep and have a solid wastegate but nothing overboard.
I would like to stick to Tial - what size should I get?
(38mm or 44mm im assuming, but which would be most beneficial?)
Cheers,
b st noob
Cheers,
b st noob
Re: What size wastegate for my SC61? (1MPOUND)
What manifold are you going to be running? A 38 will work just fine depending on the w/g placement on the manifold. The 44 is a inexpensive upgraded
Re: (Boostage)
alot of boost creep depends on the manifold style/wastegate placement. I ran 32psi with an SC61 on a Lovefab SST and 38mm WG and had no boost creep.
