Idle Problem
Setup consists of 00 Civic EX, stock D16Y8, Spoolin Performance mani, DP, Garrett T3/T04E. On intial start-up the car was idling fine, it was on the stock ECU and injectors, just for startup. Everything was fine, then the idle jumped to 3000 rpm. I shut the car off and wired in the OBD1 clips and 440cc injectors, and Uberdata. Started it up again and same high idle. At 2500-3000 rpm gauge is reading 20hg. When i make the revs drop to 1000, gauge reads 10hg. So I am thinking a vacuum leak. Replace vacuum lines and vacuum tee. Still nothing. Help with any ideas please. BTW search isnt working
Started it up with a stock P28, car idled fine for a minute. I didnt drive it. Is it possible that the car is idling proper with the sotck ecu b/c of the 440 injectors kinda bogging?
Im confused
Im confused
