identify and rate my turbo?
Old 10-17-2014, 01:32 AM
KiNGDEE206's Avatar
Default identify and rate my turbo?
So i got these 2 turbos from garrett. im assuming both are t3 and/or t4 turbos assuming from a b series turbo log manifold Supposedly a t3 flange
first. (small turbo)
.42 cold side
.36 hot side
Part # 466042 9001
Serial # QJR0212 00-00
Pat # 3058787
whats the Whp rated for @ this turbo?
Weird flange but bolts on the supposedly b series manifold
NOW a second turbo
part # 466159-5004
serial # jkm05738
i searched up this one found better results than first
found out its a 60 trim?
found another exact turbo but minus the downpipe, this ones 4 bolt. the one i found online was a 5bolt
i read for a similar but also kinda different its that it could be rated 300Whp-500Whp??
E: i found on ebay more on this turbo its a t3/t04e 60 trim rated 500whp about dope.
Old 10-17-2014, 02:44 AM
Who is Mr Robot?
wantboost's Avatar
Default Re: identify and rate my turbo?
The first turbo is a small t3, might be good for 225-250 on a small motor.
The second is a standard t3/t04e 60 trim with a stage 3 turbine wheel.
It won't support 500hp wheel hp. The wheel only flows about 46-48lb/min at it's limit. So it's only good for a theoretical 480 crank hp. You might get 450-465ish hp out of it before it's past its efficiency limit
Old 10-17-2014, 03:18 AM
Man U FTW
Schister66's Avatar
Is there a lot of shaft play in the 60 trim? The compressor inlet and turbine exit look a bit 'wet'...I'd look into that before running the turbo.
Old 10-19-2014, 01:15 PM
KiNGDEE206's Avatar
thanks guys!
There is literally NO shaft play in the 60 trim whatsoever EXCLUDING the small amount of play for clearance or whatever
Looks like ill be having fun with these 2 turbos!
i came up on the 60 trim turbo ha
I will def. look into that "wet" part ur talking about @schister66
Old 10-19-2014, 02:00 PM
I never narc'd on nobody!
NotARaCist's Avatar
The first one is a Garrett TB0325, an old Chrysler OEM turbo. Any manifold that bolts it to a B series engine would have to have been custom made - it isn't worth your time. wantboost has already covered the second one.
AFI Turbo
02-18-2015 10:24 PM
vtecallday
02-08-2007 08:36 AM
Boostin95Teg
09-19-2003 01:07 PM
HybriDNA
12-08-2002 02:22 PM
Quick Reply: identify and rate my turbo?
