Icompression?
Old Oct 23, 2002 | 10:05 AM
mrblur's Avatar
Default compression?
I have been reading all this posts, but nobody mentions lowering the compression on the engines. I would like to what would be a good compression for a turbo in a d16y7?
thanks, MrBLuR
[Modified by mrblur, 7:07 PM 10/23/2002]
Old Oct 23, 2002 | 10:17 AM
MatT3T4's Avatar
Default Re: compression? (mrblur)
I assume you are talking about a built motor.
It depends on what your power goals are, what kind of racing you do, what kind of turbo you are using, etc...
Generally though, I like my motors no lower than 10.0:1
Old Oct 23, 2002 | 10:24 AM
ekb18c's Avatar
Default Re: compression? (MatT3T4)
I
Agreed!
Old Oct 23, 2002 | 11:50 AM
Overblown-Teg's Avatar
Default Re: compression? (ekb18c)
I'm just curious what you guys are doing to make these 10:1 motors survive with high boost? If your not running high boost, why not? If your building a motor it makes a lot more sense to put some reasonable pistons in it and run 18 psi than to put 10:1 and run 8-10.. 18psi and low comp will be much faster.
Old Oct 23, 2002 | 11:54 AM
clm_Sol's Avatar
Default Re: compression? (Overblown-Teg)
Lots of tuning. There's been quite a bit of discussion in the past of high compression, lower boost vs. low compression, higher boost.
Old Oct 23, 2002 | 12:46 PM
mrblur's Avatar
building a turbo from scratch I just picked up a mitsu td05-12a turbo from a starion ($50.00).Sending it out to get it rebuilt $250.00. next is the manifold and downpipe thinking of giving drop shop a call. to lower compression I was thinking adding a gasket from mrgasket or ? any suggestions?
thanks in advance, MRBuR
d16y7
awaludinyuli
Feb 10, 2014 08:02 PM
92civtegra
Aug 15, 2007 08:26 PM
MobRacing2
Feb 24, 2006 06:43 AM
ej1 pilot
Jun 18, 2004 03:35 PM
1SIKCRX
Oct 13, 2003 10:04 PM
