Low comp on turbo motor
Old Jun 18, 2004 | 03:28 PM
ej1 pilot's Avatar
Default Low comp on turbo motor
does lowering compression on a turbo motor increase power or just allow you to add more boost safely?
Old Jun 18, 2004 | 03:30 PM
95GSRTT
Guest
Posts: n/a
Default Re: Low comp on turbo motor (Art In Motion)
more boost SAFER not safely But you will gain more power with higher compression.
Vtec92Civic's Avatar
it allows you to run more boost safely but by lowering your compression you will make less HP per LB of boost. You're best bet is to keep your compression around mid 9's if you dip into the 8's you're just starving yourself for power.
Old Jun 18, 2004 | 03:35 PM
ej1 pilot's Avatar
Default Re: Low comp on turbo motor (Vtec92Civic)
thanks guys thats all i need
awaludinyuli
Feb 10, 2014 08:02 PM
CTGrey06RSX-S
Jan 5, 2008 06:07 PM
RGSH22ACCORD
Jun 30, 2007 08:05 PM
ivebenjamin
Feb 2, 2006 11:34 PM
turbo89civicb18hatch
Nov 23, 2004 01:08 PM
