I need a Turbo!
Old Jun 22, 2002 | 01:10 PM
M.A.R.C.'s Avatar
Default I need a Turbo!
OK... people I need a turbo. I'm almost done with this setup but the only things left to buy are the turbo, manifold, downpipe, piping... all of which I can't really buy without the other ie... i can't make a manifold unless I know for sure which turbo I'll be using ,etc. I need a turbo, preferrably a T3 or comparable size or AT MOST a smaaall T3/T4. Used, rebuilt or new, just in good enough condition to put on a car without needed a rebuild right away. I'm looking to spend no more than like $300ish depending on the turbo. I know this isn't the Classified forum but I know SOMEONE in here has to have a turbo for sale. If you have any offers PM me or email me at snoops_99@hotmail.com
Old Jun 22, 2002 | 03:15 PM
M.A.R.C.'s Avatar
Default Re: I need a Turbo! (CivicRyda2k)
ttt
Old Jun 22, 2002 | 03:22 PM
bretx0r's Avatar
if its for a stock D16Y8 you are best off with either a TD04 from a greddy kit or a TD05H 14B from a 1st gen DSM, or you could take my route and go with a T25 off of a 2nd gen DSM, which is also really fun because the turbos are small so they spool up quick.
$300ish? add about $500 more to that and you got the going rate unless you have open access to a junk yard and can get parts for $0.10 a pound or free
[Modified by bretx0r, 12:24 AM 6/23/2002]
Old Jun 22, 2002 | 04:40 PM
M.A.R.C.'s Avatar
Default Re: I need a Turbo! (bretx0r)
I had a T-25.... sold it yesterday. I want A T3 or something around that size. A 14B would also be nice. Yet I don't know what I'm going to do about the oil return fittings for the 14B because no one sells them. I called RRE they only sell the whole oil return pipe. I want to do -10AN lines for oil.
[Modified by CivicRyda2k, 8:41 PM 6/22/2002]
Old Jun 22, 2002 | 06:16 PM
bigTom's Avatar
if u decide to use a 14b i could make u something for a drain for the turbo if u'd be interested
Old Jun 22, 2002 | 07:05 PM
M.A.R.C.'s Avatar
Default Re: I need a Turbo! (ek9t)
Thanks man. If I decide on one I'll let you know. What kind of flange would it be? Like I said I would want one that can fit a -10AN return line. Also what about for other turbos? I'm contemplating an IHI turbo from a guy here on H-T. I think XS Engineering should carry the flange for the IHI's but if not could you do one for an IHI RHB6W (and do u know the specs on that turbo btw)?
Old Jun 22, 2002 | 11:47 PM
bigTom's Avatar
i dont know the specs on that turbo... i have a 14b sitting at home so i can make some sort of aluminum flange for it... as for the other turbo... i dont have one and dont know the specs but if u give me an outline and dimensions of the oil return i can make it...
90Rexx
Oct 4, 2006 06:52 PM
pwerbnd
Aug 17, 2005 06:37 AM
oneforce
May 7, 2005 11:01 PM
oMek
Feb 17, 2004 07:48 PM
Anubyss
May 21, 2003 06:11 PM
